ctmullins wrote:Do you really mean "2 pair" per channel? As in, four cabs on one channel and four on the other channel? That would be 2.5 ohms on each channel, and the GX5 isn't rated for less than 4 ohms per channel, so that's a bonfire of vanity there.Bruce Weldy wrote:And no....the GX5 will not run 4 boxes with 3012LFs in 'em. Go to a GX7.y2kindyz wrote: Will the GX5 be able to run 2 pair off of each channel in the future?
I meant running 1 pair per channel, my bad. Should have read 2 cabs per channel.
thank you all for the Info.. Time to start saving up for the 3012's.
Edit: 4 or 8 Ohm?
