small rack case build
heavybdrums
Re: small rack case build
#16 Post by heavybdrums »
Bruce Weldy wrote:Question......from a ease of use standpoint, why did you put the driveracks on the bottom? It's hard enough to see those little screens without having to squat even further to get to 'em.
So that amp heat doesn't enter into the equation for the dbx. The stack is likely to have a rack box (without ears) that would have power cables and assorted items, and have wheels on it, on the bottom of the rack stack to raise it all up to a nice level and make it roll.
Also another 6u shallow rack for mains/subs/dbx and power conditioner (will move the one seen to this box). This way the whole rack stack will have wheels, be high enough, and more importantly no single box will weigh more than 50 lbs. We live in the mountains..everywhere is stairs and hills, wheels only work once on stage..not across the ground here. And mud ...did I mention the mud? This last Thur & Fri we went to a festival in North Carolina (very nice) and it rained the whole time, til we left on Sat. I couldn't imagine a heavy rack rolling across all that mud, but can imagine it being nice to move the stack once assembled and on stage to another spot on the stage.
4x WH8 delta pro
2x WH10 Deltalite 2510
4x Dr250 Deltalite II 2510
8X Titan 39 3012lf, 28"
4X Tuba 60 W/ lab 15
#17 Post by Bruce Weldy »
Thought that might be your thinking....but, it's not an issue. I have three driveracks sitting right on top of 5 Crown amps. The heat isn't a problem....and I'm running mine outside in Texas heat all summer.
BrentEvans
#18 Post by BrentEvans »
+1... Driveracks are quite durable. Rack stuff for ease of use, not temperature control.
heavybdrums
#19 Post by heavybdrums »
oh ok I had noticed that the dbx when it was sitting on the amp got hot along with the amp, it caused no problems at the time, but good to know I don't have to be worried about that.
4x WH8 delta pro
kenkenni
#20 Post by kenkenni »
Are you able to share the plans and parts list. I built one a few years back, but it was just a square
box with rack ears used to hold an amp and a BBE processor. Yours looks much nicer and professional.
heavybdrums
#21 Post by heavybdrums »
kenkenni wrote:Are you able to share the plans and parts list. I built one a few years back, but it was just a square
CUT LIST:
d=depth , w =width , h= height in inches, all parts 1/2" ply
2sides= 11&1/2(d) by 8&3/4(h)
2x top & bottom= 11&1/2(d) by 21 (w)
then for double 1/2" thick reinforcement and lip of front and back face, 2&3/4 (w) rip of ply cut to fit length, with 1/4" by 1/4" dado:
here is the front and back lip pieces to make 1" thick front and back lips for #10X1" rack screws, so you wind up with a 1/4" by 1/4" lip for the covers to fit on and some thin narrow weatherstripping for damp proofing:
Here is how the top/bottom and sides lap: Note the 4u rack rails are 7" long so the interior has to be a little more than that
Top and bottom are long, sides butt the top and bottom
These pencil drawings is all I made for them, hope it makes it somewhat clear. Just have to be sure the INTERIOR of the box winds up being about 19&1/4 wide and about 7&1/2-7&3/4 tall for a 4u box.
Where I got the rails: http://www.sweetwater.com/store/detail/RKRL4
I just used whatever surface mount handles I could get and the penn elcom corners from speakerhardware.
When you make the lids make them 1/16 or so larger than the case so they fit over the lips of the front and back without being too tight.
That's about it just a correctly sized box with lids.
4x WH8 delta pro
heavybdrums
#22 Post by heavybdrums »
Oh..just realized I didn't take a pic of the lids on:
The rear lid just like the front one only deeper to allow for cables to be left hooked up without stress on them. The clasps and handles from parts express made by penn elcom have to be surface mounted not flush or recessed.
If you notice I put the clasping mechanism on the case, if you want then on the lids(so they go away with the lids) you need to make the lids at least 2" outside depth for that to work. I was trying to make them small as possible so I made the front 1" inside and the back 2&1/2 inside and put clasps on the case where they would fit.
4x WH8 delta pro
heavybdrums
#23 Post by heavybdrums »
Just let me know if you have questions or if I wasn't clear .
4x WH8 delta pro
kenkenni
#24 Post by kenkenni »
Wow! Thanks for that. I copied all the info down and hope to start on this as soon as
I finish these last 2 2x6 SLAs. Thanks again!
heavybdrums
#25 Post by heavybdrums »
Anytime
4x WH8 delta pro
byacey
#26 Post by byacey »
Good job! I've always hated those crappy SKB racks; they are flimsy, slippery, and have next to nothing for rack rail and intrinsic strength. Lately I've been building smaller racks with 12mm plywood; it works just fine.
T48s
WH8s
SX212
T_Gowan
#27 Post by T_Gowan »
Just a note. Something we were taught in High School shop class. When we made wooden boxes for whatever use you would build an completely closed box then cut off the lid. or front and back. always a perfect fit.
IN PROGRESS Jack 10 Lite x2, hopefully 4
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
#28 Post by Bruce Weldy »
T_Gowan wrote:Just a note. Something we were taught in High School shop class. When we made wooden boxes for whatever use you would build an completely closed box then cut off the lid. or front and back. always a perfect fit.
+1 Exactly how I've built all of my boxes.
y2kindyz
#29 Post by y2kindyz »
byacey wrote:Good job! I've always hated those crappy SKB racks; they are flimsy, slippery, and have next to nothing for rack rail and intrinsic strength. Lately I've been building smaller racks with 12mm plywood; it works just fine.
Hey byacey,
Thanks for resurrecting this thread, I have been wanting to build something like this. Gave great insight. Great build Heavybdrums.
David Raehn
#30 Post by David Raehn »
Here's what I do. I have several hundred units of rack rails and love putting them to work:
http://billfitzmaurice.info/forum/viewt ... =7&t=23941
BFM rig:
6 OT12
4 T48
4 WH8
Other:
56 box Electrotec LabQ rig
Way too many cables
:noob:
