All 6 Dr250's
Re: All 6 Dr250's
#16 Post by Grant Bunter »
With a diameter of 55mm on the mounting tube, that's a bit large for a speaker stand, but it certainly is the idea...
David Raehn
Re: All 6 Dr250's
#17 Post by David Raehn »
That's the OD. It looks like it's designed for 1.5" schedule 40 steel pipe, which is ~1.9" (48mm).
Of course, it's upside down here in the States..... :D
BFM rig:
6 OT12
4 T48
4 WH8
Other:
56 box Electrotec LabQ rig
Way too many cables
:noob:
heavybdrums
Re: All 6 Dr250's
#18 Post by heavybdrums »
ty so much for the link David. I looked and maybe didn't search the right words.
4x WH8 delta pro
2x WH10 Deltalite 2510
4x Dr250 Deltalite II 2510
8X Titan 39 3012lf, 28"
4X Tuba 60 W/ lab 15
heavybdrums
Re: All 6 Dr250's
#19 Post by heavybdrums »
A thing I know: NPT=National Pipe Thread. So it's to fit black or galvanized 1&1/2" threaded pipe. That gets you close enough to adapt to speaker stand diameter with creativity.
4x WH8 delta pro
Re: All 6 Dr250's
#20 Post by Grant Bunter »
Understood guys.
What I'm trying to say is ID of a standard top hat is designed to accept a standard 1 3/8" or 35mm OD speaker stand...
Re: All 6 Dr250's
#21 Post by DJPhatman »
The linked adapter is for hanging loads from a ceiling, not the top of a stand.
heavybdrums
Re: All 6 Dr250's
#22 Post by heavybdrums »
yea I saw that this was the case. That or something like it would probably work the same way.
4x WH8 delta pro
David Raehn
Re: All 6 Dr250's
#23 Post by David Raehn »
If it can handle 500 lbs hanging(tension), it should be fine sitting (compression).
BFM rig:
6 OT12
4 T48
4 WH8
Other:
Way too many cables
:noob:
Re: All 6 Dr250's
#24 Post by DJPhatman »
David Raehn wrote:If it can handle 500 lbs hanging(tension), it should be fine sitting (compression).
Sorry, David, but not so true. The hanging tension is static, not swinging as using the linked device would put moving pressures where the device is not designed to handle them. I would suggest writing/emailing them before ordering to verify. I will ALWAYS recommend to err on the side of caution when using or making things to work out of the normal safety zones.
If it were me, I would buy a pair of the 6' tall scaffolding from Lowe's or Home Depot.
David Raehn
Re: All 6 Dr250's
#25 Post by David Raehn »
In all honesty, more than one cab on one stand scares the CRAP out of me, that's why I designed and conctructed my own solution for my OT12s. For more than two cabs per side, I plan on ground-stacking them on aluminum scaffold planks on standard scaffold. These are rated for 75 lbs dynamic per square foot.
BFM rig:
6 OT12
4 T48
4 WH8
Other:
Way too many cables
:noob:
Re: All 6 Dr250's
#26 Post by DJPhatman »
David Raehn wrote:In all honesty, more than one cab on one stand scares the CRAP out of me, that's why I designed and conctructed my own solution for my OT12s. For more than two cabs per side, I plan on ground-stacking them on aluminum scaffold planks on standard scaffold. These are rated for 75 lbs dynamic per square foot.
+1,000,000
