"Void Free" plywood - South England (Portsmouth)
Blueskink
Re: "Void Free" plywood - South England (Portsmouth)
#16 Post by Blueskink »
I've been buying sheets of 1/4 ply from Wickes. The reasons why are because its still open when I get home from work, it's in a size that fits across the rear footwell of my vw golf, it seems ok quality to me. It's not the cheapest but I haven't got time or the inclination to fanny about at a local Woodyard trying to explain what is ideal.. It does have a thin veneer but it isn't a problem to me. I haven't had much trouble with it warping.
Magic Matt Blues
#17 Post by Magic Matt Blues »
Rune Bivrin wrote:If I'm reading correctly that is NOT an expanding PU adhesive like PL Premium. :bash: Expect to be told off by the community (and they'd be right)
It seems to expand a bit when used. It kind of "puffs up" a little after its applied and looks like it oozes into the gaps. It doesn't specifically say expanding on the tubes though. I've got a few bits of "crap ply" (offcuts of 18mm cheap stuff) clamped together, and I'm going to basically smack the living daylights out of it with a hammer and see how well it holds.
Memo to self: Sticking to the plans does not mean handling them with PU adhesive on your fingers.
Also, speakers with a high SPL move a lot of air. Do not stand in front of them if you had a chilli the night before the gig.
#18 Post by Bruce Weldy »
Magic Matt Blues wrote: I'm going to basically smack the living daylights out of it with a hammer and see how well it holds.
Strength is secondary. Air tightness is primary....that's why the glue needs to expand, in order to fill all the air gaps.
Magic Matt Blues
#19 Post by Magic Matt Blues »
I was thinking of running a small line of hot glue or sealant along all the joins anyway, just to be double-safe.
Rune Bivrin
#20 Post by Rune Bivrin »
Magic Matt Blues wrote:I was thinking of running a small line of hot glue or sealant along all the joins anyway, just to be double-safe.
Assuming you intend to build one of the Titans or Tubas, just how will you do that when putting on the last side?
For the rest it's certainly doable; I've done so myself with great results. For the subs I wouldn't dare. Any truly expanding type will work, but PL Premium excels by not being runny which makes handling much easier.
In build order:
O12 with no tweeter.
3 x WedgeHorns.
2 x Jack 10 without tweeters.
2 x DR250.
2 x 16" T39
1 x Tuba 24
2 x SLA Pro (sort of...)
Magic Matt Blues
#21 Post by Magic Matt Blues »
It's a Simplexx, so I really don't think it will be a problem... but even then, it is just an additional "just in case" measure to cover my back if the adhesive hasn't made airtight seals.
Rune Bivrin
#22 Post by Rune Bivrin »
Magic Matt Blues wrote:It's a Simplexx, so I really don't think it will be a problem... but even then, it is just an additional "just in case" measure to cover my back if the adhesive hasn't made airtight seals.
Ok, then I don't see a problem. 8)
In build order:
3 x WedgeHorns.
2 x DR250.
2 x 16" T39
1 x Tuba 24
