Re: New THT Build
Posted: Tue May 13, 2014 10:37 am
				Nono... not passing you up.  I don't think!
I cut the rest of the wood last night at 10 PM... I think I might have pissed off the neighbors.
I found that cutting everything right to the dimensions listed in the plans (not the cut list) would have been very good. I have yet to find a need to re-cut anything based on warpage or other issues. The plans are perfect!
That being said, I've got the stack of panels all pre-cut for the second THT, based on how good this one went! The only things I still need to cut are the braces. Going to do that today I hope.
Going to see if I can glue on the final panels this evening.
I haven't loaded pictures because things got scary inside mine due to a few whoopsies. I had to dis-assemble/re-assemble a bit because I had one dimension wrong on my original pencil marks. I found it because the piece I cut was not the same as the pencil drawing length! The sketch and marking up the panel positions on the bottom panel is INVAULABLE!
I had to dis-assemble and the PL got everywhere! Better when the PL is still soft, then later when there's no chance for change, though! This one will be built per the dimensions (except for speaker position and brace sizes... I was a bit casual on the brace lengths), but there will be tons of misc brads popped through and glue everywhere inside...
Next one starts later this week, and it will be much better. I'll be marking all joint areas to be able to nail correctly and I'll mock it up before I start building. I hope it doesn't sound different! (but it shouldn't).
Hmmm... maybe I should build a third and use the first one as a riser rumbler!
- M
- M
