New THT Build!
Bryson
Re: New THT Build!
#16 Post by Bryson »
Well, the driver was tight, so I flipped it over and did the 5 degrees on the other end. Because I was only cutting the one side and only 5 degrees to one edge, the overall length was still the same so it came out perfect. Crisis averted! Back on track now... I also got panel 5 cut last night, so it will go in tonight.
Clamps and board to square it up. Looks good.
Stay tuned for panel 5 tonight!
Done: 2 x Dual Loaded T24 (BP102), 2 x 16in T24s (BP102), THT
Now: T18...
Next: ???
Bryson
Re: New THT Build!
#17 Post by Bryson »
Panel 5 is in, looking good....
Also, is this thing on? Feel like i'm talking to myself!
Now: T18...
Next: ???
67baja
Re: New THT Build!
#18 Post by 67baja »
Ah, building the super sub THT! It reminds me of building mine. Now come the ... Duh duh duuuummmmmm... Braces. Yuck. Keep up the good work, the reward is worth the effort!
Bryson
Re: New THT Build!
#19 Post by Bryson »
Braces, no kidding! I remember the dual braces in the T24 wide. I loved the single braces in the slim.....
Now: T18...
Next: ???
johns811
Re: New THT Build!
#20 Post by johns811 »
I remember the braces were not fun to cut on the T24. I remember thinking I wonder if I could cut several pieces of 1" dowl rod and put them in a line. Would be pretty simple to cut on the the miter saw.
Bryson
Re: New THT Build!
#21 Post by Bryson »
I think my problems brace problems on the first few builds were due to the fact that I was not square. I've learned a lot from then. I'm expecting this to go better....
Now: T18...
Next: ???
Bryson
Re: New THT Build!
#22 Post by Bryson »
Panel 6 went in tonight. Not much trouble, pretty square! Looking good! Also found another use for the W Squaring Jig!
Now: T18...
Next: ???
koturban
Re: New THT Build!
#23 Post by koturban »
:clap:
Bryson
Re: New THT Build!
#24 Post by Bryson »
Doing the braces tonight. I don't like them. I have no good way to cut 18 inch braces. Do you guys use a jig saw? I can't do it on my table saw with the miter.
Also, Bill, It appears to me that the measurements in the plans and the sketchup for the first set of braces do not match. Can you double check them?
Now: T18...
Next: ???
Re: New THT Build!
#25 Post by Radian »
Bryson wrote:Doing the braces tonight. I don't like them. I have no good way to cut 18 inch braces. Do you guys use a jig saw?
Panel jig is ideal, but I'm still not cool enough to have my own table saw. So I use a circular saw and sled which is just as accurate at the expense of convenience.
Re: New THT Build!
#26 Post by Bill Fitzmaurice »
Bryson wrote:Doing the braces tonight. I don't like them. I have no good way to cut 18 inch braces. Do you guys use a jig saw? I can't do it on my table saw with the miter.
The measurements in the plans are taken from the Sketchup, rounded to the nearest 1/16 inch, so they are spot on. You should be cutting them on your table saw using a panel jig. The safest way is to screw the blank to the jig, so there's no possibility of kick back.
Bryson
Re: New THT Build!
#27 Post by Bryson »
Ah, ok. I just checked again, you rounded up a 1/16th on both ends. That's what was confusing me. Thanks!
Now: T18...
Next: ???
Re: New THT Build!
#28 Post by Bill Fitzmaurice »
Bryson wrote:Ah, ok. I just checked again, you rounded up a 1/16th on both ends. That's what was confusing me. Thanks!
Two reasons. One, I don't expect anyone to cut with 1/16" accuracy. Second, 1/2 inch plywood isn't 1/2 inch thick, so the braces sizes if anything are rounded up to account for that.
Bryson
Re: New THT Build!
#29 Post by Bryson »
Ok, with solid advice, I made a quick jig to attach them to and first cut, perfect.... Notched them out with a router, looking good....
Top down shot...
Side shot... looking good.
Now: T18...
Next: ???
Re: New THT Build!
There should be an assembly jig connecting the outside edges of the panels to hold panel 6 squared.
