BTW, if you recess the sub into the wall, I'm assuming you will SEAL the front side from the back side of the wall? IOW, the mouth of the sub should output 100% into the room, with 0% possibility of any output bouncing around in your rafter/roof space. Then you'd wind up with a horn-loaded-infinite-baffle something or other setup. IOW, it would be a sonic mess.
SLA's and THT, First ever cab project
Re: SLA's and THT, First ever cab project
It took me a second to realize that the VW bus was NOT in the "couch picture." I'm looking and looking and all I see is the little rat dog and I'm thinking "there's no VW bus...what the hell is this guy looking at?" Then I scrolled up.
That sofa looks amazing. Build's looking pretty good too, whatever...
- Hackomatic
I'm more intrigued with the longneck in the foreground . . .billkatz wrote:Love the Lego VW bus prominently displayed - I'm also a Lego collector.
Dave H
Beer, Legos and BFM builds. All of them are favorites of mine, VW' are also a hobby of mine, but this isn't the forum for that.Hackomatic wrote:I'm more intrigued with the longneck in the foreground . . .billkatz wrote:Love the Lego VW bus prominently displayed - I'm also a Lego collector.
On the note about sealing around the sub if its installed in the wall. I planned to have a frame built around it and it would only be recessed to directly behind the drywall, equal with the front of the 2x4 stud's and frame. The output of the sub won't be obstructed by drywall, I want to put maybe speaker fabric over that area to keep "rat dogs" and my cat from getting in there.
I made some more progress last night, added two more panels. If I can add two panels a day I will be done by this weekend.
Is that an 833 in your avatar picture? Reminds me of my days minding Gates AM broadcast transmitters.Hackomatic wrote:I'm more intrigued with the longneck in the foreground . . .billkatz wrote:Love the Lego VW bus prominently displayed - I'm also a Lego collector.
1 Omni-15 Tall Boy
2 DR250s
2 Titan 39s
1 Omni-15 Tall Boy
2 DR250s
2 Titan 39s
David Raehn
BFM rig:
6 OT12
4 T48
4 WH8
Other:
56 box Electrotec LabQ rig
Way too many cables
6 OT12
4 T48
4 WH8
Other:
Way too many cables
- Hackomatic
Good eye!billkatz wrote: Is that an 833 in your avatar picture? Reminds me of my days minding Gates AM broadcast transmitters.
Yep . . I put it up to see if anyone would pick up on it. Goes back to the days when I worked on a Gates BC500GY (among others). These days it's 4CX20000A's
Dave H
The station I worked for had a Harris MW1A - one of the first solid state AM transmitters. It chewed up transistors at an amazing rate. Our backup was an old RCA with 4-400s. We had a reciprocal arrangement with the two other stations in town where I would cover for their engineers if they were out of town and both had BC-1 series transmitters with 833s. I liked the older model with the big windows in front to show the four 833s, each with 100W directly heated cathodes. They'd light up the whole room. I've heard of a few hams buying up this old iron and moving it up to 160M AM with great fidelity!Hackomatic wrote:Good eye!billkatz wrote: Is that an 833 in your avatar picture? Reminds me of my days minding Gates AM broadcast transmitters.
1 Omni-15 Tall Boy
2 DR250s
2 Titan 39s
1 Omni-15 Tall Boy
2 DR250s
2 Titan 39s
- Hackomatic
billkatz wrote:The station I worked for had a Harris MW1A - one of the first solid state AM transmitters. It chewed up transistors at an amazing rate.
Sorry tchampag . . we've sufficiently hijacked yer thread . . .
Dave H
Work continues on the THT! I really anticipate being done by Sunday, I can not wait!
Test fitting to make sure I can get the speaker on the bolts inside the access panel before I continue building.
Where I was up to last night before I started working some more.
Doing it that way is very risky, the slightest false move and you'll put a bolt through the cone or surround.tchampag wrote: Where I was up to last night before I started working some more.
If you save the round cutout from the baffle board, it can be placed over the cone to protect it while fastening the driver screws.
T48s
WH8s
SX212
T48s
WH8s
SX212
I agree its risky, what the other way to do it?
- Michael Ewald Hansen
The way its explained in the plans would be a good way to do ittchampag wrote:I agree its risky, what the other way to do it?
Authorized Builder - Denmark
Thanks, that helps a lot.Michael Ewald Hansen wrote:The way its explained in the plans would be a good way to do ittchampag wrote:I agree its risky, what the other way to do it?
Looking at page 9 paragraph 1, both the word screw and bolt is used. So I should have used screws instead of bolts. My mistake. I will correct this soon.
