Sufficient Power?
Re: Sufficient Power?
#16 Post by Bruce Weldy »
Ryan A wrote:
Their power ratings don't match. Chances are you could fry the MCM in short order with that amp.
Or, you could just turn it down....
MissileCrisis
#17 Post by MissileCrisis »
I wouldn't use an EP2000 channel without first implementing a limiter. I know from experience that even if we say it will be "so loud your house will want to cry" you will still max it out for grins (hell I took my T60 to the limiter in a 10x13 room :)). Do yourself a favor and implement some kind of protection (or buy an amp with something like 250 watts per channel). ***Do this without the sub plugged in*** You can always set the gain level on the subwoofer to a certain level such that the voltage is correct as per the plans with the volume on your reciever/mixer at max while playing a sine wave (using a voltmeter to check voltage) and use that as a sort of "limiter". As long as no one touches the gain on your amp you'll be fine.
2 x TLAH
1 Titan 39 (lab 12, 15 inch)
1 Tuba 60 (lab 12, 20 inch)
SLA Center
2 x Mini MLTP subwoofers
1 x 212 TH (custom)
2 x Mini-Karlsonators
Owned, but not built
2 x Jack 12 (2512, melded)
sine143
#18 Post by sine143 »
Ryan A wrote:
chevelle100 wrote:MCM? How low can the TT go frequency wise? And would a DSP and one channel of my EP2000 be sufficient to run it?
TT extends to 30hz or so.
Their power ratings don't match. Chances are you could fry the MCM in short order with that amp. Match the RMS ratings up to find a suitable combo. A dual loaded MCM, series wired, would probably be ok though.
was recomending series wiring. did not clearly state.
chevelle100
#19 Post by chevelle100 »
By the context I'm assuming the MCM is a driver? So you're suggesting I dual load a TT box? If I could get away with a voltmeter and the gain controls on my amp/mixer that'd be great. If a DSP is necessary in place pf a crossover to provide proper limiting then ill do what I need to.
