Do I need a track saw?
- Doug Hart
Re: Do I need a track saw?
Well, I took the plunge and ordered the Makita.
We'll see how it goes
Doug Hart, Owner
dB Pro Audio
http://www.hartdesignsetc.com
dB Pro Audio
- subharmonic
Nice pun.Doug Hart wrote:Well, I took the plunge and ordered the Makita.
it should be as accurate as your tape measure. Angle cuts shod be a breeze.
I need more bass
CW Mcall
I need more bass
CW Mcall
- Doug Hart
Haha !!! Completely unintentional. I didn't even catch it.subharmonic wrote:Nice pun
Doug Hart, Owner
dB Pro Audio
dB Pro Audio
Found these at Menards last night... Surprisingly, they were less than Rockler. A 50" is now in my possession, and will stay in the Tahoe for those emergency trips to the store where they don't have a panel saw to get me down to my 6' max length. I carry a cordless saw for just such occasions anyway.Bill Fitzmaurice wrote:I still use a 6" cordless circular saw and either a sled or guides like these, which double as clamps:
http://www.rockler.com/product.cfm?page ... te=ROCKLER
And you can get guide accessories that work with them too.
Something Witty
So I just finished setting up my old Jet table saw with a 60" fence and 5ft outfeed and infeed tables. Ripped up my first panel. Pure pleasure. No more circular saws for me.
- Harley
- Doug Hart
Yeah, I would have done that too if I had the room.LelandCrooks wrote:So I just finished setting up my old Jet table saw with a 60" fence and 5ft outfeed and infeed tables. Ripped up my first panel. Pure pleasure. No more circular saws for me.
Doug Hart, Owner
dB Pro Audio
dB Pro Audio
If I make a cut that's 1/16" out in one direction, and another on the opposite side that's 1/16" out in the other direction, you get a panel that's 1/8" out.Rune Bivrin wrote:If you're out by 1/8" using the Makita you're doing it wrong. No offense, but you should be within 1/64". Either you've got a dodgy measurement setup or you're cutting on the wrong side of the line.el_ingeniero wrote:I've got the Makita tracksaw and a Skil battery powered circular saw.
I've been able to better accuracy with the Makita than with the circular saw on a sled. But that means on some pieces I could be as much as 1/8" out. There are places where you want to do better, like a DR throat.
IMO, a decent table saw with judicious upgrades and a pile of jigs is the key to super accurate cuts.
I had a cheap B&D circular before, and that sucker wouldn't cut straight, but the Makita is completely predictable.
It's not so much a matter of measurement as it is how you place the track.
And after a while that little strip of plastic along the rail gets beat up enough that it's not a reliable indicator of where the blade will cut.
What happened with your Sawstops?LelandCrooks wrote:So I just finished setting up my old Jet table saw with a 60" fence and 5ft outfeed and infeed tables. Ripped up my first panel. Pure pleasure. No more circular saws for me.
Well, the contractor model is at my son's shop. My original sawstop is in my Dad's shop which I've been using for the last 3 years. It replaced the jet, which has been in storage. I bought another sawstop for the new shop, because I did not want my 90yr old father running a standard saw. The jet became a panel saw for big cuts only.
- Rune Bivrin
I don't quite follow. Why are you cutting the panels twice? If you've got a good, straight edge on one side you measure and cut the opposing edge. That's just one cut.el_ingeniero wrote: If I make a cut that's 1/16" out in one direction, and another on the opposite side that's 1/16" out in the other direction, you get a panel that's 1/8" out.
Either way, my track has seen quite a few cuts, and apart from where there's a nasty mark due to an early handling failure
In build order:
O12 with no tweeter.
3 x WedgeHorns.
2 x Jack 10 without tweeters.
2 x DR250.
2 x 16" T39
1 x Tuba 24
2 x SLA Pro (sort of...)
3 x WedgeHorns.
2 x DR250.
2 x 16" T39
1 x Tuba 24
Haven't built any DRs yet? Check out some build threads. Lots of beveled cuts and non rectangular shapes.Rune Bivrin wrote:I don't quite follow. Why are you cutting the panels twice? If you've got a good, straight edge on one side you measure and cut the opposing edge. That's just one cut.el_ingeniero wrote: If I make a cut that's 1/16" out in one direction, and another on the opposite side that's 1/16" out in the other direction, you get a panel that's 1/8" out.
Mine has seen more than a few handling failures in a few hundred cuts. But I'll probably buy another plastic strip soon, since I've pretty much learned every way there is to hose a cut with it and haven't messed it up very much in the last few weeks.Rune Bivrin wrote: Either way, my track has seen quite a few cuts, and apart from where there's a nasty mark due to an early handling failureit still cut's right at the edge of the rubber strip.
Track saws have a great edge in safety over a normal circular saw, but you still have to honor the tool:
* Wait until the blade is up to speed before you plunge
* use a sacrificial piece of MDF or cheap ply under the workpiece.
* clamp the track down over the workpiece; use spacers when the workpiece is small. For really tiny work pieces, screw the piece to the sacrificial surface.
* Let the spring in the plunge mechanism lift the blade all the way out of the kerf, then lift the saw off the track.
- Rune Bivrin
I have done 2 DR250 and 2 T39:s with the track saw. The Omni 12, 3 wedgehorns and two J10 were built with the old circular. The wedges in particular were no fun, which was why I invested in the track saw...el_ingeniero wrote: Haven't built any DRs yet? Check out some build threads. Lots of beveled cuts and non rectangular shapes.
I think that's the heart of the matter. One of the strong points of the Festtool and Makita is that by default it cuts right at the edge of the rubber strip. Once that precision is compromised you're SOL.el_ingeniero wrote:Mine has seen more than a few handling failures in a few hundred cuts. But I'll probably buy another plastic strip soon, since I've pretty much learned every way there is to hose a cut with it and haven't messed it up very much in the last few weeks.Rune Bivrin wrote: Either way, my track has seen quite a few cuts, and apart from where there's a nasty mark due to an early handling failureit still cut's right at the edge of the rubber strip.
All sound advice, but I have pretty much never needed clamps for the track other than for very small parts. The neoprene strip keeps it in place just fine as long as you make sure the surfaces are free from saw dust. Make sure you go slowly, and plan for managing the cord when the cuts get long. Few things are more annoying than wondering why the saw is stuck, only to realize you're standing on the cord...el_ingeniero wrote: Track saws have a great edge in safety over a normal circular saw, but you still have to honor the tool:
In build order:
3 x WedgeHorns.
2 x DR250.
2 x 16" T39
1 x Tuba 24
3 x WedgeHorns.
2 x DR250.
2 x 16" T39
1 x Tuba 24
LOL. Done that a couple of times myself, along with the hose getting caught.Rune Bivrin wrote: I think that's the heart of the matter. One of the strong points of the Festtool and Makita is that by default it cuts right at the edge of the rubber strip. Once that precision is compromised you're SOL.
The Festool rubber track strip is replaceable if one is ever in doubt of the accuracy.
So how did you make less than 4 cuts for the throat horn and the sides? Just saying ...Rune Bivrin wrote:I have done 2 DR250 and 2 T39:s with the track saw. The Omni 12, 3 wedgehorns and two J10 were built with the old circular. The wedges in particular were no fun, which was why I invested in the track saw...el_ingeniero wrote: Haven't built any DRs yet? Check out some build threads. Lots of beveled cuts and non rectangular shapes.
