Well.....it's summer here...you could move. And with the humidity we have here, winters would not pose a curing problem.....and we have Golf Courses you'd die for!Bill Fitzmaurice wrote:. But it won't set worth a damn below 60 degrees.
Mo
Yup. Gorilla Glue and the Elmer's poly version both make that recommendation. And it's a good alternative to working in dry conditions in the winter. A quick wipe with a damp rag, then gluing and clamping before the moisture evaporates will take the place of humidity.Harley wrote: For the100% expanding polyurethane glues and there was a recommendation - that for quicker curing and a better joint, you dampened the surfaces to be glued.
