It won't sound good, and if you're pushing them past xmax and/or Pe damage will eventually be the result. But a clipped signal in and of itself is no more injurious to a sub than is water to a duck's back.unsafe8989 wrote:So if I clip my subwoofers constantly even non stop at times its fine?
Amp for 3012LF
Re: Amp for 3012LF
unsafe8989
Re: Amp for 3012LF
The IPR 3000 is 440 watts @ 8 ohms? how is that too much power?Gregory East wrote:Clipping in the amp you mean? That'll be way too much power for the lowriders. Even if it isn't it would sound lousy.
Square waves of themselves are harmless.
Re: Amp for 3012LF
Figure on a clipping amp delivering double the rated power for a brief period. See how that sounds if you dare. I wouldn't.
and last time you were talking about them being bridged. Pick up pieces of lowrider after that!
unsafe8989
Re: Amp for 3012LF
It sounded fine without bridgeing But who knows maybe these digital amps can give a bad burst?Gregory East wrote:Figure on a clipping amp delivering double the rated power for a brief period. See how that sounds if you dare. I wouldn't.
Re: Amp for 3012LF
I'd guess the new DDT system is just as good as the old one then.
unsafe8989
Re: Amp for 3012LF
Reading on the peavey forums apparently when driving into DDT isnt really clipping, yet it allows you to know that your near limit per say like a soft limiter am I correct. Just a bit of research I did during school.Gregory East wrote:I'd guess the new DDT system is just as good as the old one then.
