I seeeeeeee. I've not really looked at the plans for these yet but they're on the list for some point this summer. Thanks.fitzwaddle wrote:^^^ that![]()
Then as far as # of tweeters, the choice was driven by balancing desired length of the tweeter line, impedence matching, and sensitivity matching. More info in my Q&A thread before I nailed down the parts list:
http://billfitzmaurice.info/forum/viewtopic.php?t=16761
a pair of TLAHs (rectangular)
Re: a pair of TLAHs (rectangular)
SirNickity
If it's in your budget, I use a Weller WES-51. Hot in one minute, variable temperature, digitally controlled. About $90-100 most places. L-O-V-E it, having just upgraded from a Radio Shack $10 pencil iron.fitzwaddle wrote:I think I need to break down and get a better soldering iron - the one I have is never hot enough - any recommendations?
A little pricey, but I'm a big fan of this Weller kit.fitzwaddle wrote: ...
Sydney
Not when you consider how long they last.shawn_g wrote:A little pricey,..
I have a small Weller iron that I've had for decades, and a largest Weller ( for the really big stuff ) that is even older.
I have exactly the same one and I love it. I tried a cheaper one from another company....took it back the next day as it wouldn't get hot enough to solder a 12ga. wire. Hell, it wouldn't hardly melt solder at all.shawn_g wrote:A little pricey, but I'm a big fan of this Weller kit.fitzwaddle wrote: ...
Spend the forty bucks - you'll be glad you did.
- Michael Ewald Hansen
Buy once, cry once. Never seems to get old!Bruce Weldy wrote:I have exactly the same one and I love it. I tried a cheaper one from another company....took it back the next day as it wouldn't get hot enough to solder a 12ga. wire. Hell, it wouldn't hardly melt solder at all.shawn_g wrote:A little pricey, but I'm a big fan of this Weller kit.fitzwaddle wrote: ...
Authorized Builder - Denmark
fitzwaddle
It has been a while - too many projects and other todos - and the weather is getting nicer, so of course need to mix in some outdoor activities on the weekends. I made some more progress and getting close. I have both crossovers built, all the finishing is done, one is wired up and tested, just need to wire the other one up, test, and do the fill.
Here's a few pics. I decided to go with "claret wine red" for the face instead of black, to give some contrast with the black drivers - the lighting / camera seems to make the front more pink than in reality:
here's one of the crossovers, used 1/8" masonite for the board:
My initial test setup - iPhone running Pandora to $20 Lepai amp, in a garage - only have one channel wired so far, but I like what I hear initially, even with the improvised test setup, looking forward to hearing both running on a proper AVR with EQ and a sub, and in a better room.
- Harley
Mmmmm....me likey!
Sweet.
Absolutely! Drop dead gorgeous88h88 wrote:That red looks gorgeous.
fitzwaddle
Thanks a bunch guys! Not quite up to the level of those Jatoba grill ones I saw in the authorized builders' showcase, but I like them.
I covered the little "hat" grills I made with speaker cloth; stuffed the cabinets with poly fill, and screwed the backs on. Then sat in the driveway listening to them for a while. Hmm, I guess I'm done. :p
Tomorrow I'll bring them inside and wire to the AVR in the living room, and see if I can find the calibration mic for the AVR that I must have tossed in one of my many boxes of electronic doo dads. (&(*(@!#
Then I guess I have to see if I can fix my old Velodyne VA-1215 sub that died a while back, since these need low end help (as expected).
- Scott Brochu
Nice contrast from wood to red.
Well done.
Drumming is a way of life.
ME LIKE TO HIT THINGS!
fitzwaddle
Thanks Scott.
Oh well, so they are either going into my home office which will become part listening room, or in the HT - I'm thinking the former, since I'm already planning SEOS based LCR build for the HT. And I kind of like the "no visible speakers" look I have in the HT, and it would be a shame to hide these behind a screen after putting work into a presentable finish. Office it is!
Hmm scratch that - I talked to WAF about putting them in the living room, she was OK with it, then I brought them in, and she changed her mind.fitzwaddle wrote:Tomorrow I'll bring them inside and wire to the AVR in the living room, and see if I can find the calibration mic for the AVR that I must have tossed in one of my many boxes of electronic doo dads. (&(*(@!#
