+1. There's no such thing as a free lunch. The power gains from bridging increases current draw, which increases heat, which decreases component life.Tom Smit wrote:Aaaaaand, if you run hard too close to the minimum load too often, you shorten the life of said amp.
8 ohm vs 4 ohm loading
