Avanti? I have, used it once and got a Diablo. This is definitely a case of buy once, cry once.NCcrashman wrote:I just replaced the saw blade with a 142 tooth, 7 1/4" blade with a 0.090 Kerf. What do you think Bill?
~Patrick~
crashmans' O-Top 12 build is finally under way!!
el_ingeniero
Re: crashmans' O-Top 12 build is finally under way!!
NCcrashman
I will say this too though I have no clue how it could matter, but the saw manual say's to use a 7 1/4" blade and what I just took off was nooooo 7 1/4" blade. The one I just replaced it with is!!
~Patrick~
~Patrick~
"If it's too loud, your too old! What's that? I didn't hear you"
Friends don't let friends use crappy speakers!
NCcrashman
No..not Avanti..it's a off name brand. I'll get the Diablo.el_ingeniero wrote:Avanti? I have, used it once and got a Diablo. This is definitely a case of buy once, cry once.NCcrashman wrote:I just replaced the saw blade with a 142 tooth, 7 1/4" blade with a 0.090 Kerf. What do you think Bill?
~Patrick~
NCcrashman
EL, not at ALL questioning you or anything but just so I'll know, why does the blade matter so much??
NCcrashman
Funny enough, I cut the wood for the cut table perfect. It's as true and square as you could make it..lol. that's what's so frustrating.
~Patrick~
~Patrick~
- Jon Barnhardt
A good blade makes a big difference in chipping and straight cuts, but a 1/16th of an inch is usually not the end of the world, depending on which cut it is...
NCcrashman
Mostly a 1/8th and some have been even more. I also think cutting on the furthest part of the line I draw is important too. I've always wondered about what part of the line to cut on. I say the furthest edge since the pencil lead is so much larger. Newly cut as much as I can make it. I also bought a titanium, like a scratch awe that looks like a pen. Makes a much thinner line.Jon Barnhardt wrote:A good blade makes a big difference in chipping and straight cuts, but a 1/16th of an inch is usually not the end of the world, depending on which cut it is...
Thanx for all the help guy's.
~Patrick~
- Jon Barnhardt
check out eurekazone.com
I have a tracksaw table from them (DIY table) and it takes the guesswork out of cutting straight, accurate cuts.
Frederic Gelinas
How can you be off by 1/8 with a cutting sled? Maybe you are doing something wrong. You clamp your guide on the piece you measured and want to keep. Your saw is supposed to slide on your guide, the blade cutting exactly on the edge. This method should be very accurate.
Frédéric Gélinas, HF Audio
HFAudio.ca
Free tone Generator
HFAudio.ca
Free tone Generator
That would be a steel 'plywood blade', which I never use. Steel blades dull quickly, then they get hot and warp and you can't cut a straight line. You should have a carbide blade, 40 to 60 tooth. Freud Diablo is very nice.NCcrashman wrote:I just replaced the saw blade with a 142 tooth, 7 1/4" blade with a 0.090 Kerf. What do you think Bill?
~Patrick~
http://www.mcfeelys.com/product/DIABLO- ... ish-Blades
- Rune Bivrin
It's possible if the edge of the shoe isn't exactly parallel with the blade. I had that issue with a crappy B&D circular saw. Messed up every single cut by varying degrees depending mainly on the length of the cut.Frederic Gelinas wrote:How can you be off by 1/8 with a cutting sled? Maybe you are doing something wrong. You clamp your guide on the piece you measured and want to keep. Your saw is supposed to slide on your guide, the blade cutting exactly on the edge. This method should be very accurate.
In build order:
O12 with no tweeter.
3 x WedgeHorns.
2 x Jack 10 without tweeters.
2 x DR250.
2 x 16" T39
1 x Tuba 24
2 x SLA Pro (sort of...)
3 x WedgeHorns.
2 x DR250.
2 x 16" T39
1 x Tuba 24
This statement alone tells me that you didn't build a sled. With a sled, the size of the shoe isn't important. Also, you talk about using scribe lines vs. a pencil - that too tells me you don't have a sled. With a sled, you only need to measure and make a mark on each side of the panel, then lay the sled on those two marks.NCcrashman wrote:The balde to the edge of the saw shoe measure 1 3/8. I've measured it God only knows how many times so I know it's right.
In the amount of time that you try to line up and make 4 cuts with a guide board, you could build a sled that would be much more accurate and way faster.
el_ingeniero
I use a battery operated saw with a 7-1/4" blade (although I've let my folks know I really want a Festool track saw for Christmas;)). This means that the saw blade and technique have a huge impact on battery life and my productivity.NCcrashman wrote:EL, not at ALL questioning you or anything but just so I'll know, why does the blade matter so much??
The Diablo finish blades have a few things going for them over standard type blades:
* thin kerf (the poart of the work piece that becomes sawdust)
* that red color is an anti friction coating
* the slots cut into the blade and the gaps in the edge without teeth reduce vibration
* the teeth have a better profile for cutting
All of that reduces the cutting resistance quite a lot.
Technically, I've found 2 things important:
1) Setting the depth so that the saw just barely pokes through the workpiece by a 1/16th inch or so. This makes it so 2 or 3 times more teeth are cutting through the wood at the same time, each tooth cutting a much smaller swath and overall the saw doesn't work as hard.
2) Making sure the workpiece is well supported so the blade doesn't pinch. That means there is something every 12 to 24 inches, and within 6 or 8 inches from the ends. The classic way to do this is to cut on a sacrificial surface (or just raise the piece off your work bench with scrap lumber). Sacrificial surfaces do make for nicer cuts on the bottom. Some people go so far as to build work benches with a sacrificial top or supports, and at least 2 companies sell such benches: EurekaZone (EZ-Smart table) and Festool (MFT/3). Radial arm saws are just giant circular saws on arms, and they have a sacrificial surface as part of the design.
el_ingeniero
My Skill brand battery operated saw has its blade to the right of the handle with the cutting direction away from me. With the blade set at 0 degrees, the distance from the left edge of the shoe to the blade is exactly 5 inches, and that's the part that sits on top of the sled.Bruce Weldy wrote:This statement alone tells me that you didn't build a sled. With a sled, the size of the shoe isn't important. Also, you talk about using scribe lines vs. a pencil - that too tells me you don't have a sled. With a sled, you only need to measure and make a mark on each side of the panel, then lay the sled on those two marks.NCcrashman wrote:The balde to the edge of the saw shoe measure 1 3/8. I've measured it God only knows how many times so I know it's right.
+1Rune Bivrin wrote:It's possible if the edge of the shoe isn't exactly parallel with the blade. I had that issue with a crappy B&D circular saw. Messed up every single cut by varying degrees depending mainly on the length of the cut.
Yours must have been from the same batch as mine. It burned out before it saw any serious use. In hindsight I'm glad it did. Couldn't make a straight cut *with saw sled*. Bought a new saw (different brand), made a new sled. Nice straight cuts ever since.
I think it is likely that your circular saw is the source of the problems NCCrash, not the blade or the sled. Since you are low on cash, I'd look for a cheap or free way to find out about your saw. Can you borrow a circular saw from someone for one day? Make a sled and try a few cuts. You would know right away when that makes good cuts.
