Exaxtly the kind of answer I was looking for. Thank you.Bill Fitzmaurice wrote:Read it again, then consider that you can't hear +,-2dB deviations.
One thing that drives me nuts with oddiophiles is that half the time they worry themselves half to death over anything that they can see on a chart, whether it's audible or not, while the other half they claim to magically hear stuff that can't be measured at all.
TLAH Pro - CNC Build
GirlyHandedDog
Re: TLAH Pro - CNC Build
GirlyHandedDog
Good info Mitch. Fortunately I ordered a few extras so I could have the option of running 4 banks of 5 tweeters for a slightly higher impedance if needed. In the plans Bill mentions an acceptable range of impedance ratio between woofer and tweeter. I should be right in the acceptable range.BassMe wrote:Hey,
Check the impedance charts carefully for those tweeters. At about the cross over range the impedance is actually very low, down around 4-5 ohm. In that thread I linked there is two links to zaph audio where he has done his own impedance chart measurements, which when you look closely actually reflect the SB charts as well. i dont know where they get off calling them 8 ohm realistically.
And its no problem, I have been looking for a guinea pig for them for a while
I make a pretty good guinea pig...there will be plenty of mistakes to learn from in the end.
All I can say is these TLAH Pro are going to be beasts!
Have you chosen your cross over point yet? I was looking to cross at about 3000Hz or maybe even a tad lower at about 2600Hz.
Glad to be of help, least it reconfirms my own thinking
Have fun!
Have fun!
GirlyHandedDog
I was thinking of sticking with 3500Hz. I'd like to go lower if possible, but I wouldn't want to limit my max output by crossing over too low. I think SB mentions their recommended range is 3k - 20k.BassMe wrote:Have you chosen your cross over point yet? I was looking to cross at about 3000Hz or maybe even a tad lower at about 2600Hz.
They came in today from Madisound, here's a pic (sorry for the crappy cell phone quality):
Reading plans, it mentions that when using more of fewer tweeters than 8, to stick with 2 parallel banks. Maybe I'm doing my math wrong, but with 16+ tweeters, that puts my tweeter line's impedance at just over 1 ohm. Am I still okay with going with 4 banks of 5 tweeters, or 3 banks of 6 tweeters, parallel wiring the tweeters in each bank, then series wiring the banks together? If I do it this way, I come out much closer to 4 ohms I believe. Just trying to understand the reasoning of sticking with two parallel banks.
Last edited by GirlyHandedDog on Fri May 04, 2012 12:16 pm, edited 1 time in total.
Simplified wiring. If you have so many tweeters that you need to run more than two banks by all means do so.GirlyHandedDog wrote:Just trying to understand the reasoning of sticking with two parallel banks.
They look far less truncated then I thought they would lol. Are you planning to rear or front mount?
I would say SB recommends 3k as the lowest point cause people commonly use 1st and 2nd order crossovers. Using a 3rd order, I reckon you'd be fairly good to go down to 3k.
GirlyHandedDog
I'll be doing a front mount. It will almost be like the multi-element single mouth horn in the plans when using the piezos, since I won't be separating them with any vertical spacing, and the tweeters are already pre-cut/truncated. As far as the amount of truncation, it could be an optical illusion based on the camera angle in the previous picture. Here's a couple of straight-on shots:BassMe wrote:They look far less truncated then I thought they would lol. Are you planning to rear or front mount?
Very good point, something I hadn't considered before. I guess I'll have to play around with it using an active crossover then decide what sounds best before building a passive hp filter.BassMe wrote:I would say SB recommends 3k as the lowest point cause people commonly use 1st and 2nd order crossovers. Using a 3rd order, I reckon you'd be fairly good to go down to 3k.
Last edited by GirlyHandedDog on Tue May 01, 2012 6:21 pm, edited 1 time in total.
Looks good, now you just have to seal them all in... could be the fun bit.
Active crossover testing is just cheating, be a real man and guess!
But seriously, that is definetitly the way to do it, look forward to your results.
GirlyHandedDog
It took a bit or searching, but I was able to find out where the cabinet guys get their material from. Found some 4x8 baltic birch sheets in 1/2" and 3/4" for the baffle. It was a bit more expensive than I was hoping ($50 for 1/2 and $62 for 3/4), but nevertheless I picked them up anyway. They also had some "paint grade" non-baltic birch that looked like it would work great and was only $26 for 1/2" and a bit more for the 3/4" thick; however, apparently paint grade is synonymous with "this stuff is cheaper so let's scratch and ding the crap out of it when we move it around the warehouse." Needless to say, I stuck with the baltic.
One of the outer plies was quite thin on both sheets, so I'll have that face the inside of the cabinet:
I'm hoping to route these later today...
Last edited by GirlyHandedDog on Tue May 01, 2012 6:22 pm, edited 1 time in total.
GirlyHandedDog
Routing in progress:
Last edited by GirlyHandedDog on Mon Nov 07, 2011 5:30 pm, edited 1 time in total.
GirlyHandedDog
Finished up the routing. Here's a few pics along the way:
An extra baffle, because there was room... and just in case.
Last edited by GirlyHandedDog on Tue May 01, 2012 6:22 pm, edited 2 times in total.
GirlyHandedDog
Last edited by GirlyHandedDog on Tue May 01, 2012 6:23 pm, edited 1 time in total.
Wow, just wow!
Tall son'bitches.
TLAH Pro - "I fear no floor or ceiling!"
Okay so now I really want a cnc router. Where can I get plans?
