CHEAP SPKR CABLE: SPEAKON TO SPEAKON
Re: CHEAP SPKR CABLE: SPEAKON TO SPEAKON
doncolga wrote:should I tin the ends before putting them in the Neutriks?
No, bare copper holds better.
#17 Post by Bruce Weldy »
here's the ones you want... NL4C
http://www.neutrik.com/en/speakon/fc-series/nl4fc
doncolga
#18 Post by doncolga »
Bruce Weldy wrote:here's the ones you want... NL4C
The place I got my cable from does carry these and will exchange the ones I've got for some of those. They indicated they're much better too, just more expensive.
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
DanielNY
#19 Post by DanielNY »
Interesting, I never used those heads and since I cut them off I don't know if mine were in the same condition. I bought a batch of Neutrik Speakon NL4 heads, about 10-12, which still put the total cost below $100.00 for 100ft of custom size 12G cable. Still a good deal.
Harley
#20 Post by Harley »
+1 - in fact I tried tinning the ends when I first used Speakons and found very quickly that tinning ruins "the grip"
rec
#21 Post by rec »
I bought a 25ft cable and am making 5ft speak on (neutrik)jumpers for my (4) t30's. The factory end that I am leaving in
place has solder on the wire connection in addition to the screw. Is this necessary? There is really not enough room to
get a small soldering tip in there with out melting the connector.
Thanks
4xT30(24", 4012HO loaded)
1xAT
wallywally
#22 Post by wallywally »
rec wrote:I bought a 25ft cable and am making 5ft speak on (neutrik)jumpers for my (4) t30's. The factory end that I am leaving in
Thanks
Soldering is not required on a screw type connector. If you ever need to remove that connector just cut it off.
Builds:
T-39
DR 280
Wedgehorn 8
Omni 12
SLA
TAT
TLAH experimental
BrentEvans
#23 Post by BrentEvans »
I like the 4X better.
http://www.neutrik.com/en/speakon/spx-series/nl4fx
#24 Post by Bruce Weldy »
Ok Brent, you made me go look.
You're right - the twist on housing of the X is a little better than the C. I have mostly Xs and just a couple of Cs.
They both work good. I think the Cs are a little cheaper.
BrentEvans
#25 Post by BrentEvans »
Bruce Weldy wrote:Ok Brent, you made me go look.
It's not just the housing. The screw terminals on the X are better too. They insert at an angle and are easier to work with.
Worth every penny of the cost difference... which is usually about $2... less... :)
Remember, snarky... blood sugar... don't mind me....
Dave Non-Zero
#26 Post by Dave Non-Zero »
They have I higher amp rating too.
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
doncolga
#27 Post by doncolga »
The ones I've been getting locally are 2FC's and the 12 gauge is proving to be tricky getting in...not sure how I did it the other evening, but the ones I tried today didn't work....the wire was just too thick. The 2 pole diameter only accepts up to 10 mm where the 4FC's to to about 15mm. Now I do have one 4FX and it goes up to 14.5 mm and it was really easy to wire, taking a wider diameter and super easy access to the screws.
Donny Collins
BrentEvans
#28 Post by BrentEvans »
doncolga wrote:The ones I've been getting locally are 2FC's and the 12 gauge is proving to be tricky getting in...not sure how I did it the other evening, but the ones I tried today didn't work....the wire was just too thick. The 2 pole diameter only accepts up to 10 mm where the 4FC's to to about 15mm. Now I do have one 4FX and it goes up to 14.5 mm and it was really easy to wire, taking a wider diameter and super easy access to the screws.
It's generally OK to snip a few strands of wire to make a connector fit... as long as there's enough for good mechanical fit (at least half or so). NL4s are designed for #14 stranded IIRC. Use a small flush cutter to take off a few strands of #12 and it works just fine.
doncolga
#29 Post by doncolga »
Under Technical Information this says these work with 10-12 AWG and the 2FC says it's for 12 AWG...maybe my cable is actually 10 AWG...
Donny Collins
Dan30
#30 Post by Dan30 »
doncolga wrote:http://www.neutrik.com/en/speakon/spx-series/nl4fx
I got NL4 connectors for Leland the ebay cables were kinda hard to bet it I had to twist and squeeze em down with needle noses to get them in the holes.
SLA Pro x 2
Yamaha S112V x 1
QSC RMX 2450
dbx Driverack PA
