I was just trying to figure out how many wires I am going to need to run from the jack panel in the back to the driver cavity. Also decided to color code the wires to help keep from getting confused.
I will have a busy jack panel. I have three combo 1/4"+2-conductor speakon jacks and SPST switch to have both 8 and 4 ohm top capability.
Assuming the x-over goes in the driver chamber, I thnk that means I will need to run 5 wires between the chamber and the back panel:
- one black lead from the jacks' common ground to the driver's ground;
- one red lead from the x-over in to the inductor, the 10uF poly cap, and one of the 125 uF electrolytics;
- one green lead from the caps to the top-out jack;
- two white leads from the 125uF electrolytics.
I mapped it out like this:
http://www.frappr.com/?a=viewphoto&id=1 ... myphotos=1
Does this look about right?
4 & 8 ohm crossover in a T39
I was not aware of your thread either...not sure how I missed it...but that's why I like crosslisting. Others who look at this topic may want to look at yours as well...so...Tim Ard wrote:I didn't even see this thread before I posted mine. Woulda' saved me some trouble.
http://billfitzmaurice.com/phpBB2/viewt ... ght=#14430
