That's because you left the filters out.wallywally wrote: 2) At the level he wanted to play, distortion and ear fatigue became a problem.
TLAH Experimental
Re: TLAH Experimental
So I didn't expect a TLAH pro with closeout drivers to match a DR280 for full band gigs, or to even match the TLAH pro with Alpha 6a. But for a minimal investment (~$80 for the pair) I'm thinking about trying to build one, with filters.
It would be good for
- an interesting shootout with SLA Pro
- mobile party / home theater applications
- small gigs in long narrow rooms where I just mix vocals and acoustic guitars
- vocal PA (weddings, etc)
For the price it seems worth a try!
also, this might sound crazy but I didn't see the answer in the plans... I'm just curious why SLA and TLAH mount the 1016s in "vertical" mode instead of a stack of horizontal piezo horns like a non-melded array in a DR/otop/wh?
wallywally
I think you'll be very pleased with the results. I wouldn't hesitate to build these for your purpose.mattaudio wrote:So I didn't expect a TLAH pro with closeout drivers to match a DR280 for full band gigs, or to even match the TLAH pro with Alpha 6a. But for a minimal investment (~$80 for the pair) I'm thinking about trying to build one, with filters.
I don't want to give the impression that I'm unhappy with the results of my TLAH's....I'm not. They perform beyond my original expectations (they currently reside in my home theater). The only part of this equation that didn't meet my expectations was my guitarist and his unreasonable volume/mix requests. If I had not substituted the DR280's, I would have worked out the minor gripes I had with the TLAH's. Many factors went into my decision, I simply followed the path of least resistance.
Builds:
T-39
DR 280
Wedgehorn 8
Omni 12
SLA
TAT
TLAH experimental
T-39
DR 280
Wedgehorn 8
Omni 12
SLA
TAT
TLAH experimental
How did you come up with using 5.25" drivers instead of 8" drivers?
wallywally
It was an experiment, and price was the primary factor. 4"-6" drivers are acceptable for HT duty. The original plan was to use them in low volume situations and possibly move up to the pro version if it was needed. After building them, I discovered that the DR280's I already have fit my needs best, so the TLAH experiment has not progressed.mattaudio wrote:How did you come up with using 5.25" drivers instead of 8" drivers?
Builds:
T-39
DR 280
Wedgehorn 8
Omni 12
SLA
TAT
TLAH experimental
T-39
DR 280
Wedgehorn 8
Omni 12
SLA
TAT
TLAH experimental
wallywally
I found some really crappy video that I took when I finished these. The sound is low and has some hiss but still is not bad. It illustrates how well the TLAH works at throwing sound for a distance and how much bass they can produce. These are run full range, slightly corrected with a 3 band eq.
Builds:
T-39
DR 280
Wedgehorn 8
Omni 12
SLA
TAT
TLAH experimental
T-39
DR 280
Wedgehorn 8
Omni 12
SLA
TAT
TLAH experimental
Are you Tom Hanks? You sound like Tom Hanks...
wallywally
You've discovered my secret88h88 wrote:Are you Tom Hanks? You sound like Tom Hanks...
Builds:
T-39
DR 280
Wedgehorn 8
Omni 12
SLA
TAT
TLAH experimental
T-39
DR 280
Wedgehorn 8
Omni 12
SLA
TAT
TLAH experimental
I've just found this thread, and I must say that I'm very impressed by their output on your videos!
It's inspired me to re-think the speaker choices I want to make for my studio when I can get around to it. Considering that these are 6 feet high, as someone else mentioned in another post, in an 8 foot high room these would work very well, teamed with something like a TT or a THT.
But, from what I've heard from Bill is that Davids may be more useful for music, because of better imaging, although this was a comparison with the Davids and the SLAs...so how would these fair instead?
Thanks for taking the time to experiment!
Current builds in use:
2 x T18
Past builds:
2 x SLA
Omni15
Autotuba
2 x T18
Past builds:
2 x SLA
Omni15
Autotuba
wallywally
I personally would not use them in a studio. Listen to the video's again and hear the combing/phasing as the mic moves up and down the speaker. If your close to them vertical combing is an issue. In a studio the speakers should be close, a line array is not the the right tool for the job IMHO.
Builds:
T-39
DR 280
Wedgehorn 8
Omni 12
SLA
TAT
TLAH experimental
T-39
DR 280
Wedgehorn 8
Omni 12
SLA
TAT
TLAH experimental
