In any configuration, you need one cable per cab. A Y adapter won't make a difference to that. I'm I missing something?Traijin wrote: To wire the two cabs per channel I would run a speakon to a cab and daisy chain to the other cab? It is a lot more cable than what I really should need. Is there a splitter cable or block so the signal can be split at the amp?
Digital Crossover Necessity
Frederic Gelinas
Re: Digital Crossover Necessity
Frédéric Gélinas, HF Audio
HFAudio.ca
Free tone Generator
HFAudio.ca
Free tone Generator
I already have a pair of 25' speakons, which worked fine with the music station centered. Its a little petty to concern myself with the value of the already owned cables, but it is in my nature to be sure I am doing things efficiently. It seems like a pair of 25' for the short run is excessive, but I want around 25-35' between the cabinet stacks. So I need 2 45-50' cables to daisy chain from cab to cab.Frederic Gelinas wrote:In any configuration, you need one cable per cab. A Y adapter won't make a difference to that. I'm I missing something?Traijin wrote: To wire the two cabs per channel I would run a speakon to a cab and daisy chain to the other cab? It is a lot more cable than what I really should need. Is there a splitter cable or block so the signal can be split at the amp?
This is a total of 150' of cable to daisy chain.
whereas if I used a pair of splitters at the amp I could be using a total of 100' of cable.
The extra cost of cable is one issue (like washed out or even surpassed by cost of Y's) What about signal strength/integrity?
Is 50' inconsequential assuming the correct gauge of wire is used?
Apologies for the stream of consciousness.
2 SLA's Curly Maple Baffle
2 Jack 15's 3015 Loaded
4 Tuba 30's Delta LFA Loaded
You only need one long cable to run from speaker to speaker. The run from the amp to one speaker will use the 25 footer you already have. Are you really spreading your mains 30-40 feet apart? Must be some monster rooms that you are in.Traijin wrote: So I need 2 45-50' cables to daisy chain from cab to cab.
hmmmmm.... I just caught this.Traijin wrote: I want around 25-35' between the cabinet stacks.
By cabinet stacks, you aren't talking about running subs underneath each top, are you? If that's why you need two long cords, then you need to educate yourself about proper sub placement.
It should be:
AMP to Speaker 1 - short cable.
Speaker 1 to Speaker 2 - long cable.
Amp to Sub 1 - cable length dependent on where you place the subs
Sub 1 to Sub 2 - short jumper as they should be right next to each other.
Duly noted and appreciated, never really thought it matter too much for sub placement since it will be outdoors, at my parties, overlooking a few acres. Not very conducive to principles of placement. Bu I read you, and appreciate all your help for sure. I will read up on kit placement a lot more.Bruce Weldy wrote:hmmmmm.... I just caught this.Traijin wrote: I want around 25-35' between the cabinet stacks.
It should be:
Thanks
Hello, my name is Bruce and I was a sub splitter.....
I haven't created a power alley in one year and two months.
(group applauds and has a group hug)
- Dave Non-Zero
Bruce Weldy wrote:Hello, my name is Bruce and I was a sub splitter.....
Hello Bruce.
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
Hi, Bruce!
