Wow, that is a reality check. So, with two T39s, go with two OTop 12s? or two Jack 112s perhaps?Bill Fitzmaurice wrote:The cabinet. With two OTop 15s you need at least two T48s to have a balanced system. By the same token if two T48s are more subs than you need then two OTop 15s are more tops than you need.KTOKTO wrote: Thanks for the info. Rookie question here... by "size", do you mean the surface are of the drivers?
My First Cabinet Build (pics)
Re: My First Cabinet Build (pics)
Two OTop 12 or two Jack 10.ripNdeb wrote:Wow, that is a reality check. So, with two T39s, go with two OTop 12s? or two Jack 112s perhaps?Bill Fitzmaurice wrote:The cabinet. With two OTop 15s you need at least two T48s to have a balanced system. By the same token if two T48s are more subs than you need then two OTop 15s are more tops than you need.KTOKTO wrote: Thanks for the info. Rookie question here... by "size", do you mean the surface are of the drivers?
I always find it amusing when I see on other forums guys with 2x15 tops asking what single small sub they can use with them.
Very nice man. I hope to post pics of my Otop 12's soon. These will be playing with my pair of 18" Tuba 30's.
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
Thanks for the info. Two T48s are in the works.
Got the 2nd cabinet built and am powering with a Behringer EP2000 350wx2 at 8ohm. We moved the 4 ohm resistor bewteen the capacitor and the lead. The tweeter array was a little hot by default. Sounds fantastic now. Really impressed.
Off to build the T48s now.
- Steve Regier
It is all my 4 T48s can do to keep up with my four Otop15s. I would say that they almost need 2 more T48s. Consequently we have to more T48's planned for build.
"BaronVonSteve"
"BaronVonSteve"
