first drs
SeisTres
Re: first drs
#16 Post by SeisTres »
jesuchete wrote:Yeah they are huge. I am thinking I need to do a jack or a smaller dr or the smaller venues. I am wondering if the jack would be better than a say a dr20 or dr25. Cost of the Dr300 right now is at about 450. I have smaller venues with about 1000 people how many jacks would I need.
You would still need subs. And in that case you could do ot12's and you could use them for side fills or center fills for the really big events. Anything more than 250 and jacks start becoming impractical.
jesuchete
Re: first drs
#17 Post by jesuchete »
Happy new to everyone. Hoping you had a great time working all those gigs.
I am looking at my system a little more carefully. I have completed my dr300 and I will be posting the pictures soon. I was thinking of building dr200 instead but I will be able to put up a few extra. Looking at Bill`s estimated crowd numbers there is not much difference between the except weight and mobility. The other fact is that I have to ship these in knockdown form. I can get 5x5 sheets from my local lumber yard would one sheet be enough for a dr200?
Re: first drs
#18 Post by DJPhatman »
jesuchete wrote:Happy new to everyone. Hoping you had a great time working all those gigs.
You are on the right path for your needs. The DR300 is exactly the cab for your needs. You would need 3X as many DR200/DR250, and the DR300 is usable for your "smaller" gatherings. None of the Jack cabinets are appropriate for your needs. The smaller DR2xx would require more cabs, so you would not save any money. Keep checking for shippers who are willing to donate, or reduce cost, for your religious agency. Good luck!
Mikey
Re: first drs
#19 Post by Mikey »
DJPhatman wrote:You are on the right path for your needs. The DR300 is exactly the cab for your needs. You would need 3X as many DR200/DR250, and the DR300 is usable for your "smaller" gatherings ... The smaller DR2xx would require more cabs, so you would not save any money.
There's also the issue of amplifiers. For instance, if you plan to run two cabs per amp side (4 ohms), that's four cabs per amp. So if you use twice as many cabs (DR300 / DR200) you will need twice as many amps. Granted, they'll be smaller amps, but they're still likely to cost you more, overall.
You DO realize that you're going to have to fly these line arrays, right? Have you had rigging engineered for this?
Will you be using T48s for subs?
Albert Einstein
Israel
Re: first drs
#20 Post by Israel »
!!!!!!!sound for a million people!!!!!!!! I sometimes wonder if sound coverage is a matter of space covered rather than how many peeps are there in and or how noisy those people are...... well i just grab to the fact that in sound matters even with all those logical rules you just got to do what you know is right and then pray... thats what i think you have gone the right way Jesuchete go on fellow builder and God follower I (and i think many more here) am more than anxious to see your system running so keep us well informed
MADE
4- OT12'S BETAII
4 T39'S 20" 3012LF LOADED
ON THE BENCH: 2 OT212
jesuchete
Re: first drs
#21 Post by jesuchete »
Thanks Israel for your encouragement. Once again thanks to Bill. Has any one bought the new beringer amp. I must say Iam tempted to plunge into these. I have read a lot of reveiws from various supplier sites and many of them don`t say much that is bad about them. I know that the mixers are iffy but how about the amps.
UROK
Re: first drs
#22 Post by UROK »
What happened with this build? Was looking good...
Purely a disinterested enquiry.
Not that I am planning to build DR300s or anything, ahem. :mrgreen:
Re: first drs
#23 Post by DJPhatman »
jesuchete wrote:Has any one bought the new beringer amp. I must say Iam tempted to plunge into these. I have read a lot of reveiws from various supplier sites and many of them don`t say much that is bad about them. I know that the mixers are iffy but how about the amps.
Quite late for replies, but most reviews, even on here, are favorable. Behringer amps are known to stand up pretty decently.
jesuchete
Re: first drs
#24 Post by jesuchete »
been a while. This is a question for those who have built the Ot15. How much plywood do I need for for one. i will be using arauco which available at Loewes in 4x8 sheets
Re: first drs
#25 Post by Tom Smit »
A single 4x8 or just a bit more than a 5x5.
jesuchete
Re: first drs
#26 Post by jesuchete »
hey Tom. I am in kitchener. I would love to come and hear your OTs how far am i from you.
Re: first drs
#27 Post by Tom Smit »
About two and a half hours away.
BTW, I don't have OTops. Actually they are Omni10.5s, 23" wide with melded arrays, S2010 loaded....precursor to the Jack110.
Harley
Re: first drs
#28 Post by Harley »
LelandCrooks wrote:Man those things are big. The only cab I haven't built.
They're not for the faint hearted that's for sure. :mrgreen:
