Or you run it through the table saw thinking it's scrap. Done that more than once.bzb wrote:coolhandjjl wrote:Just a tip here, label your jigs. The W are obvious, but sometimes you make a jig and stash it away... a good bit later you find it and say: what the hell is this for?
W Clamping Cauls
Re: W Clamping Cauls
Jeez, I did that on my final panel of the last T39 to make braces.LelandCrooks wrote:Or you run it through the table saw thinking it's scrap. Done that more than once.bzb wrote:coolhandjjl wrote:Just a tip here, label your jigs. The W are obvious, but sometimes you make a jig and stash it away... a good bit later you find it and say: what the hell is this for?
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
I used a nice piece of birch ply for something unimportant. It was different width from the remaining stack of ply pieces that I intended to use for a second T18. Should have noted that the piece that I cut was intended for the sides
No more decent quality birch ply available in my area at this time, yet another self-
I thought I was the only one.
Great idea, I have some scraps and would like to make these.
How big are they? Estimating from the pictures, are they about 12" long? (the sides where the c clamps attach to)
Or should I go bigger?
I have two pairs of different sizes....one about 8 inches and another around 10 inches. Make a bunch in different sizes.bean438 wrote:Great idea, I have some scraps and would like to make these.
- Harley
That's where a flouresecent pink spray paint can comes in handyLelandCrooks wrote:Or you run it through the table saw thinking it's scrap. Done that more than once.
