Omni 15 Tallboy
Re: Omni 15 Tallboy
wounded horse wrote:Interesting as I'm currently looking at parametric preamps. I find that as I try to home in on frequency bands and try to dial out what I can only call resonant harshness, I lose headroom. Anyone use parametric eq? Any recommendations where I should be looking?
To control boom set the Q (bandwidth) to middle of the scale, set the gain to -10 to -12dB, set the frequency to 30-32 Hz to start. If the cab booms sweep the frequency control upward until it goes away. Increase the Q, which reduces the bandwidth, until you hear the boom start to occur again, then reduce the Q a smidge. That will notch the boom without affecting anything else. I don't use parametric for anything but boom notching, for everything else standard shelving and peaking filters work better and are easier to deal with.
Gauss
Re: Omni 15 Tallboy
#17 Post by Gauss »
wounded horse wrote: Do any of you guys have that weird situation where you tune up on a quartz or multi effects inbuilt tuner and then you play, say a low G and its fifth above and it doesn't sound like a fifth but that the D sounds like C#.
Have you checked your intonation? What you're doing is changing the length of the string (adjusted at the bridge) in order to make the string in tune while open, and while played at the 12th fret. The rest of the frets will be in tune at that point. In reality some frets are not perfectly in tune even when correctly set-up. Maybe you're one of the lucky ones that can hear the difference.
BASS: Combo Amp & Titan39
Re: Omni 15 Tallboy
#18 Post by Tom Smit »
wounded horse, may I suggest that you wait getting the other parts until you've tried out your O2X12. It might resolve your dilemma. 8)
WB
Re: Omni 15 Tallboy
#19 Post by WB »
wounded horse wrote:I have used an Aguilar 2X12 for the past 3 years
I used one of those for about a year, and found it to be very muddy sounding, and inefficient. The worst direct radiator cab I've ever owned. I think you'll find your O15TB to be a big improvement.
