 !now I'm considering to build two T48 (even if they're too tall) insted of a couple of T39.
But now I'm sure about DRxx. better build a couple of DR200 or 250 then four OT12.
Hehe, things will clear up before you've made your decision.mcmarte wrote:damn...I'm more confused then before open this topic!
The T36 is 36" tall and 36" deep, the T39 is 39" tall and 20" deep. The T36 is a lot bigger.mcmarte wrote:anyway I was looking at chart comparison and... Tuba 36 (with one woofer) seems to be stronger then T39..especially in the 20/60 Hz Frequency! It look really to be a little bit less powerful then T49.
This is really Interesting!
You're incredibly right man! but at this point i would choose LOUD and LOW...and not small!Turntablist wrote: If you want a speaker to be loud and go low it won't be small, if you want a small speaker that can be loud you wont be able to go low, if you want a speaker that can go low and to be small it won't be loud.
The trick is to decide how loud, how low or how small your speaker has to be.
 :iitp:Gregory East wrote:Could be a good case for super slim 10" driver BP102 T48's? How wide are they?
Not T39.mcmarte wrote:ok ok...decision almost done.
2x DR200 and 2x T48 or T39!
Actually not itp, not my new version plans, because Bill deemed BP102 unworthy of T48 after the 3012LF came into production.Harley wrote::iitp:Gregory East wrote:Could be a good case for super slim 10" driver BP102 T48's? How wide are they?
just out of curiosity, what size baffle hole on the 10" version, is it the same as the T39?RubiconProSound wrote:+2...not in my plans either.
I remember Bruce mentioning the HL10c would fit in a 14" wide T48 with good results but I don't remember anything about a BP102 being used...(although it's assumed they would be ok just less output than the HL10c's...)
I mentioned it once before as an option for DJ's wanting to use them for the extended low end response over the T39, but no replies...
the 3012 or 3015 is surely the way to go with a T48, but if you already have a few BP102s floating around it might not be a bad option. My T30's are a pain to lug around, a slim T48 with handles and skids would be cake to pull up the occasional staircase.
4 BP102s are required to match one 3015LF.Gregory East wrote:Actually not itp, not my new version plans, because Bill deemed BP102 unworthy of T48 after the 3012LF came into production.Harley wrote::iitp:Gregory East wrote:Could be a good case for super slim 10" driver BP102 T48's? How wide are they?
You could possibly pile 4 slims on a back seat. A lot cheaper than buying a trailer or upgrading vehicle.
Who's got the old plans and will spill the beans?
