Page 92 of 93
Re: What's to chat about?
Posted: Thu Jun 12, 2025 8:38 pm
by Old Mike
Seth wrote: ↑Wed Jun 11, 2025 10:17 pm
Old Mike wrote: ↑Wed Jun 11, 2025 9:14 pm
Seth,
As a very long in the tooth retired engineer, (and I think you're probably there already regards this recommendation), when a "transport device" comes with spares the reason is usually due to frequent prior failures. I'd strongly suggest you replenish the parts you have used from the inventory before venturing too far from land. I'm vicariously enjoying your journey, just wish I was young enough to do the same thing.
Thanks Mike. Wise words, indeed. While the seller is considerably young at 33, he's owned the boat since he was 20. My read on the situation is, he's taken on the safe route of having spares for anything that that can wear out or run out. Like you're suggesting, my guess is he learned the hard way a time or two. The boat holds 150 gallons of fuel throughout 4 separate fuel tanks, which is a lot if you sail everywhere and can get 5+ mpg at a gallon per hour when you do run the engine. He had 6 kegs with welded in bungs as well as two 30 gallon barrels for additional fuel capacity on board when I bought it. He also insisted we have 10 gallons of motor oil and 10 gallons of transmission fluid prior to making our journey. The boat
is 47 years old and it is a boat afterall, there's always going to be something broken. I will definitely follow your wise advise and his lead prior to shoving off into the great blue yonder and carry spares of anything that can wear out or run out. Although, I got rid of the kegs in favor of having a usable dinner table and booth.
I'm happy to hear you're following along and enjoying the journey vicariously. It really is an intention of mine to present the journey in a way that brings the viewer along for the best possible experience as if you are there. I'm still learning how to do that effectively. There were so many things I should have filmed over these past few weeks that I didn't. I'm finding myself spread thin and trying to juggle more balls than I know how. Are you following along just here, or on YouTube too?
https://youtube.com/@sailingelsie
Another new development, I've received my first unsolicited donation/contribution to the endeavor through the "buy me a coffee" link on my website. $25 from one of my boat neighbors. It's not really the money, it's more the genuine recognition for how I show up for people in the world and how they see me. Feels really good. I'm completely honored that they would do that. I mean, it was always my intention to have it all be crowd funded. But it's nicer, just for the recognition it represents.
And Mike, I'm honored to have you along for the ride. Thank you. One of my best friends is 76 and disabled from a stroke a few years back. I visit him in the care facility frequently. It means I won't be able to anymore, but I'm doin it for him too. Anyone who can't or otherwise wont do it them selves, I hope you all enjoy the journey.
Thank you Seth,
There is an honesty and integrity surrounding people that love music and it's reproduction, that keeps the wind in my sails.
best wishes for a following wind long into the future
Mike
Posted: Fri Jun 13, 2025 4:36 am
by Keryn O'Shea
Seth wrote: ↑Tue Jun 10, 2025 12:00 pm
..I pulled the engine out 5 times in 6 days before I finally solved the issue. It's been an adventure! More to come!
You could do it blindfolded
Hopefully that was the last time though. How about spare fuel filters & water pumps..? Also a fuel additive which prevents fungal growth. Prop shaft gland seal..? And a head gasket, or chemical sealer which adds to the coolant at least.
Posted: Fri Jun 13, 2025 9:06 am
by Seth
Keep the suggestions coming. I can't think of everything and I want to be as reasonably prepared as I can be, before I set out. Of those you mentioned, I currently have 6 spare fuel filters, one spare engine coolant pump (water pump), and a spare packing gland. On my shopping list, I have listed a spare raw water pump and at least two spare impellers. I'll get more packing glands too. They're cheap and when ya need one or know someone that needs one, it can be an urgent situation. On your advice, I'm going to add a head gasket and fuel additive to the list, Thanks Keryn!
Posted: Fri Jun 13, 2025 10:14 am
by AntonZ
Spare alternator
A few spare injectors and glow plugs (your engine is most probably a diesel unit)
Posted: Fri Jun 13, 2025 5:14 pm
by Seth
Hahaha... yeah, about those glow plugs. It's back on a momentary button now, but for a time they were activated by connecting two wires with spade connectors. One morning I woke up to dead batteries. Hmm. Wonder what happened... instant palm to forehead as it struck me in the same moment. I forgot to disconnect them after the engine started. And I did it again a few days later! What a dumb ass. I put it on the momentary button THAT day. They're cheap, ordering at least two more sets for the spares box. Injectors! Great suggestion. By the time I leave, I'm gonna be a mobile marine hardware store!
Posted: Fri Jun 13, 2025 9:57 pm
Hmmm, may as well add a fuel pump to the list.
How about spare rope, and pulleys, and mast splints?
Posted: Sat Jun 14, 2025 2:35 pm
by AntonZ
Seth wrote: ↑Fri Jun 13, 2025 5:14 pm
Yep, glow plugs are cheap and an easy replacement. Don't know how many cylinders your engine has. If it has four, it most probably still starts on two or three glow plugs, but it does get hard on your batteries if they start running low in cold weather. Cheap and easy are repairs you should not postpone. Good job on the push button instead of spade connectors. Injectors going bad looses power and makes your motor run sloppy. And bad on fuel consumption. Your fuel supply is a limited and valuable asset on board. Better have that motor running smooth as silk.
Filters are no brainer supplies: air, fuel and oil filters. These are also cheap and easy replacements.
Not sure what it is called in english, but make sure you know about water separation on your fuel intake. Usually placed right next to the fuel filter on diesel engines that I have seen. Those were mostly trucks and tractors, I don't know the common layout on marine diesel engines. Check for water in the fuel there. If necessary drain all excess water from the water separation unit. You don't want water going into your injection pump.
Tom Smit wrote: ↑Fri Jun 13, 2025 9:57 pm
The fuel pump tends to be the most expensive part on a diesel engine. And if your fuel and filters are OK it should last a long time while glow plugs and injectors have a more finite life span. Also, installing and setting a new fuel pump on a diesel engine is not as simple a job as replacing a glow plug. Taking a spare injection pump only makes sense if you know how to get it installed and running properly.
Then again:
"should last a long time" is my submission for this week's Famous Last Words
Posted: Sat Jun 14, 2025 4:15 pm
by himhimself
Some solar panels and storage batteries?
Assuming you're all over safety/emergency supplies/first aid supplies. And an EPIRB
Posted: Sat Jun 14, 2025 9:51 pm
+1 on water separation for the fuel.
Posted: Mon Jun 16, 2025 10:36 am
by Seth
So, this particular fuel/water separator (Racor) has an integrated filter. Sight glass and water drain on the bottom, filter replaces from the top.
I currently have three deep cycle and one starting lead acid batteries onboard. I'll be investing in a quality LiFePO4 battery bank. There are currently three 350 watt solar panels, but they're partially shaded by the boom. Not enough to keep up with the 3.5 amp refrigerator compressor 24 hours a day. There's an unshaded location made for two 465 watt bi-facial panels that I'll probably fill this week. The previous owner removed them and put them on his new boat.
I made a liar of myself. Not even 4 weeks of ownership and I've made a meager, yet impactful upgrade to the stereo and added a small amplifier and subwoofer I had laying around. No tuning other than a little twist of the amps gain to taste. Massive improvement to fullness and listenability. I find myself looking around for a location to put a horn sub. Not seeing one yet.
Posted: Mon Jun 16, 2025 2:47 pm
by AntonZ
Seth wrote: ↑Mon Jun 16, 2025 10:36 am
You know it is time to start looking for a bigger boat when....
Posted: Mon Jun 16, 2025 8:03 pm
by Seth
Hahaha... got a genuine laugh at that one.
Thanks Anton.
Posted: Mon Jun 16, 2025 10:45 pm
Good.
Seth wrote: ↑Mon Jun 16, 2025 10:36 amI currently have three deep cycle and one starting lead acid batteries onboard. I'll be investing in a quality LiFePO4 battery bank. There are currently three 350 watt solar panels, but they're partially shaded by the boom. Not enough to keep up with the 3.5 amp refrigerator compressor 24 hours a day.
A good start.
Seth wrote: ↑Mon Jun 16, 2025 10:36 amI made a liar of myself. Not even 4 weeks of ownership and I've made a meager, yet impactful upgrade to the stereo and added a small amplifier and subwoofer I had laying around. No tuning other than a little twist of the amps gain to taste. Massive improvement to fullness and listenability. I find myself looking around for a location to put a horn sub. Not seeing one yet.
That didn't take long.
Posted: Thu Jun 19, 2025 1:21 pm
by Old Mike
Seth consider using a bactericide treatment on your fuel tanks. Growths can and do occur at a hydrocarbon/water interface, especially in warmer climates, and can plug filters incredibly quickly.
Posted: Thu Jun 19, 2025 4:02 pm
by Seth
Good advice. Thanks Mike. I'll investigating treatments ASAP.
