Page 10 of 10
Re: DR200 (x4) Build Thread
Posted: Sun Feb 27, 2011 2:31 pm
by Lastcat
Dave, what did you decide for handles? Still pondering that one myself.
Lastcat
Posted: Sun Feb 27, 2011 7:12 pm
by SoundInMotionDJ
Lastcat wrote:Dave, what did you decide for handles? Still pondering that one myself.
My DR200's have no handles. They also have no grills. Reaching into the horn mouth and using the side braces is enough leverage to be able to pickup and get the cabinets on and off stands.
--Stan Graves
Posted: Sun Feb 27, 2011 7:24 pm
by David Carter
http://www.speakerhardware.com/penn_spr ... h7154k.php
Posted: Fri Jan 27, 2012 3:42 am
by chenry78
[quote="David Carter"]Been slow going lately, but I've got two of the boxes Duratex-ed with corners and speakon jacks installed. I'll take some close-ups later on. This morning I wired up the one melded array I've built so far in order to test my high pass filters. I was nervous going into the test because of the problems Scott had with his after following my wiring diagram. It turned out OK, however. I ran a signal through the array with no filter and then I wired it through the filter, and everything worked! :) I still have to test my other filters, but the first one worked fine.
This close-up exaggerates many of the imperfections due to dust and lighting, but as you can tell, my array is not perfect. But at this point, I don't have the patience to do any more work on it, so it's staying like it is. Fortunately, it doesn't look as bad from a few feet away. :lol:
Image[/quote
I hope my arrays look that nice when I get done!! :clap:
Posted: Fri Jan 27, 2012 3:54 am
by Grant Bunter
The dowel down the middle of that array should sort out the imperfections looks wise, as long as it's soundly constructed...
Posted: Wed Feb 01, 2012 7:25 pm
by loudsubz
Clean array
