8 x DR250 build
Re: 8 x DR250 build
should be fixed now
Re: 8 x DR250 build
CoronaOperator wrote: My amp rack for this room used to weigh over 100 lbs and just the sub amp alone would trip the breaker for that outlet. Everything is on one 15 amp breaker for this setup and output levels that have no problem exceeding 130 dBC.
And you should still have some room left....
I run 6 subs, 4 tops, and 6 monitor mixes (7 Crowns/3 Driveracks/mixer/fan) off a single circuit. After three years of shows outside, I've yet to flip the breaker.
