DR200 (x4) Build Thread
Scott Brochu
Re: DR200 (x4) Build Thread
#121 Post by Scott Brochu »
Chris_Allen wrote:I repositioned the crossover so I could have one pair of DR200's with hats in both sides - this was so I could stack them using a short piece of 35mm connecting pole.
Where did you end up repositioning the crossover?
Drumming is a way of life.
ME LIKE TO HIT THINGS!
#122 Post by Chris_Allen »
Scott Brochu wrote:Where did you end up repositioning the crossover?
Good question! I'm not sure where I put it. I'll have to take a cover off and take some pictures.
NCcrashman
#123 Post by NCcrashman »
WOW!! What a GREAT thread! It was crazy informative and answered a questioned I had. I was going to build 2 DR-250's, but I believe I like the idea of the four 200's instead.
Man, I really enjoyed this. Well done and thank you so much.
Patrick
"If it's too loud, your too old! What's that? I didn't hear you"
Friends don't let friends use crappy speakers!
David Carter
#124 Post by David Carter »
NCcrashman wrote:WOW!! What a GREAT thread! It was crazy informative and answered a questioned I had. I was going to build 2 DR-250's, but I believe I like the idea of the four 200's instead.
Glad it was helpful, and good luck with the build. Make sure you share your journey also. :)
Dave
- 2 x Titan 39 (BP102 - 14"W)
BoostFab
#125 Post by BoostFab »
I really like the idea of the tin/metal back halves. Does it affect sound in any way?
David Carter
#126 Post by David Carter »
I don't believe it has a significant impact. Of course, I've never built DR200's without the metal in order to compare. But regardless of whether they're the same or not, they sound great!
Dave
SeisTres
#127 Post by SeisTres »
BoostFab wrote:I really like the idea of the tin/metal back halves. Does it affect sound in any way?
soundinmotiondj was actually the one that started doing the metal thing. I'm pretty sure he hasn't had any problems with them. Might want to PM him just to verify.
#128 Post by LelandCrooks »
Nah, Harley was.
David Carter
#129 Post by David Carter »
@BoostFav, regardless of the origins, Stan (SoundInMotionDJ) does indeed have a herd of DR200's with the metal butt cheeks, and he uses his a lot more than I use mine, so he will definitely be able to offer an opinion on how they sound.
Dave
BoostFab
#130 Post by BoostFab »
well, I guess that does give itself away being tin halves are non-issue, since you both have deployed the herd. :-) I'm very tempted on switching from ot12 and build the dr200, after digesting the plans like 10x it doesn't look too hard IMO
Trauma11
#131 Post by Trauma11 »
great build and log
Lastcat
#132 Post by Lastcat »
Just a short question, it's ok to add poly-fil inside this area, good to go?
LC
Currently Built:
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
#133 Post by Bill Fitzmaurice »
Lastcat wrote:Just a short question, it's ok to add poly-fil inside this area, good to go?
LC
Yes, just don't pack it tight.
SoundInMotionDJ
#134 Post by SoundInMotionDJ »
I have 10 metal butt'd DR200's. They sound fine to me. No vibration. No buzzing. Clear. Articulate. Stupid loud.
But, I have not heard a wooden butt'd DR200 to compare against.
10 T39S + 10 DR200 + 1 T48
Lastcat
#135 Post by Lastcat »
LC
Ok, thanks Bill.
Currently Built:
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
