Simplexx 212 build w/ Pics
Electric Wisdom
#121 Post by Electric Wisdom »
Bill Fitzmaurice wrote: Tue Apr 03, 2018 8:48 pm Those are products to put in the walls of buildings. Read Rule #1 again. :horse:
Yes i'm trying to but i don't see it in the build pdf document :(
It just says "damping" in the Damping section near the end of the pdf.
I think i read that document 5 times from start to finish since i first started the build lol
Damping just means the general concept of it right? Or is it a brand in usa or something?
Can you please tell me where it talks about it in the doc? Thanks :)
:hyper:
#122 Post by Bill Fitzmaurice »
Page 14: Damping material lines the back. You may use an inch to two inches of acoustical foam or open cell urethane mattress topper foam (not memory foam), or polyester pillow stuffing or upholstery batting, available at fabric stores and department stores. It may be attached with staples or spray adhesive.
Electric Wisdom
#123 Post by Electric Wisdom »
Bill Fitzmaurice wrote: Wed Apr 04, 2018 3:48 pm Page 14: Damping material lines the back. You may use an inch to two inches of acoustical foam or open cell urethane mattress topper foam (not memory foam), or polyester pillow stuffing or upholstery batting, available at fabric stores and department stores. It may be attached with staples or spray adhesive.
Ohhh damn sorry about that, it was right before the "Damping" heading in the doc.
Electric Wisdom
#124 Post by Electric Wisdom »
Could someone show me an example image or in a online store of the foam used?
I see many types, i'm not sure, is it white material?
Is it the same as the acoustic panels in pro audio recording studios??
Canadians, where you get them?
Last edited by Electric Wisdom on Wed Apr 04, 2018 5:48 pm, edited 1 time in total.
#125 Post by Bruce Weldy »
Electric Wisdom wrote: Wed Apr 04, 2018 5:45 pm Could someone show me an example image or in a online store of the foam used?
Mattress topper can be found at Wal-Mart or any big box department store.
https://www.amazon.com/LUCID-Inch-Tradi ... ess+topper
It can be flat or egg-crate...
Electric Wisdom
#126 Post by Electric Wisdom »
Bruce Weldy wrote: Wed Apr 04, 2018 5:48 pm
Oh sweet! thanks, going to walmart now!
Electric Wisdom
#127 Post by Electric Wisdom »
Last edited by Electric Wisdom on Wed Apr 04, 2018 5:54 pm, edited 1 time in total.
#128 Post by Bruce Weldy »
Electric Wisdom wrote: Wed Apr 04, 2018 5:51 pm I thought it would be less expensive.. lol
https://www.walmart.ca/en/ip/zinus-2-ge ... 0197350342
You really need to read closer......
Do NOT get memory foam. Do NOT get gel.
It's a cheap foam mattress topper. Shouldn't be more than $20-25 for a twin size.
#129 Post by Bruce Weldy »
Electric Wisdom
#130 Post by Electric Wisdom »
Bruce Weldy wrote: Wed Apr 04, 2018 5:53 pm
yes i just see it was a memory sorry
Electric Wisdom
#131 Post by Electric Wisdom »
Bruce Weldy wrote: Wed Apr 04, 2018 5:54 pm Here......
$13...
https://www.walmart.com/ip/Authentic-Co ... r/34174394
Thanks!!!
Electric Wisdom
#132 Post by Electric Wisdom »
There's not this product on walmart canadian, and its about the same price converted to cad.
Seems like this one is ok, not gel, not memory, about the same price not the same brand but its fine right?
https://www.walmart.ca/en/ip/mainstays- ... 0197196827
Electric Wisdom
#133 Post by Electric Wisdom »
damnit, it says memory gel in the description, not the title, none on canadian website are not gel or memory :(
seriously they all mention either gel or memory, cant find one that isnt...
#134 Post by Bruce Weldy »
Electric Wisdom wrote: Wed Apr 04, 2018 5:59 pm damnit, it says memory gel in the description, not the title, none on canadian website are not gel or memory :(
You may have to order it from amazon.....or try another store. You can check a mattress store, but it will probably be more expensive there.
Electric Wisdom
#135 Post by Electric Wisdom »
Bruce Weldy wrote: Wed Apr 04, 2018 6:35 pm
yea i tried amazon.ca theres nothing non gel or non memory, i found one on ebay but it will be like 60$ cad
https://www.ebay.ca/itm/Authentic-Comfo ... 1edc160bab
or maybe this one
https://www.bestbuy.ca/en-ca/product/bo ... 03148.aspx?
