Stereo Power Amps: different signals to different speakers?
Is this amp OK?
ryansalmond
#1 Post by ryansalmond »
I want to run both a guitar signal, and a vocal signal through a power amp. Can one stereo power amp send the guitar signal to a guitar cab and the vocal signal to a PA cab? or will I end up with both signals going to both cabinets.
Thanks.
"GOT QUESTIONS? NEED HELP?
Chat with other builders on the Forum. You can benefit from the experience of literally hundreds of builders/owners to decide which speakers are right for you, and how to build them. "
Haysus
Re: Stereo Power Amps: different signals to different speakers?
#2 Post by Haysus »
Gonna need more info. I.E. model of amp? Are you plugging directly in to the amp?Impedance of both cabs?
4 20" T39(built)
2 WH8(built)
3 WH10(own)
4 DR200(own)
1 Jack 12(built)
SAC 24 Channel Mixer
SAW STUDIO Recording
ryansalmond
#3 Post by ryansalmond »
I will be plugging into a PreSonus Firestudio for the vocal preamp and a Sansamp California for the guitar preamp. I was thinking 8 ohm cabinets, but that's a variable as I haven't built them yet. I'm just wondering if two signals can be kept totally separate by a stereo power amp.
#4 Post by LelandCrooks »
As long as it has separate inputs for each channel. But, we need more info.
ryansalmond
#5 Post by ryansalmond »
I was thinking one of these: http://www.qscaudio.com/products/amps/rmx/rmx.htm
into an omni212 (guitar, no tweeter) and two daisy-chained wedgehorns (vocals)
gdougherty
#6 Post by gdougherty »
ryansalmond wrote:I want to run both a guitar signal, and a vocal signal through a power amp. Can one stereo power amp send the guitar signal to a guitar cab and the vocal signal to a PA cab? or will I end up with both signals going to both cabinets.
Thanks.
Usually you'd have at least a small mixer in the middle there. What are you trying to accomplish?
novasak
#7 Post by novasak »
+1 : add a small mixer before the amp. Pan guitar to one side, and vocals to the other side. Just make sure they are always panned appropriately before you turn on/up. You get much more control using a mixer instead of just plugging strain in.
