  But probably holding something else in line.
 But probably holding something else in line. I think that's the camera lens doing that.Scott Brochu wrote: That bottom pannel on the cab looks like it is a bit out of wack
Were here to help you so ask qestions and reread the plans over and over again.boammusic wrote:yea thats the lens doin that, the bottom is fine, i stood it up on its bootom for the first time today. Im having a little trouble with the mid horn, this being my first atempt at wood working, but im going to have my uncle help me out with it. he is a wood worker for a profession, so he can make it fit in the hole i cut in the front no problem. but he also has what i need to cut the two speaker spacers. then i just have to brace it up and cover it in tolex and load it.
It's easier and better to cut the hole after the horn is made ... a little late now, I know.boammusic wrote:so he can make it fit in the hole i cut in the front
Nice work! You should be very proud of your achievement.boammusic wrote: This is also my first expirience working with wood in any way, so it didnt turn out perfect.
