Autotuba questions - drivers and box width
Wingnut601
Hello,
I'm looking into making a large AT for the back of my Ford Flex. I can go 40" wide on it and would like to do so. Would it be reasonable to run 3 10" drivers or stick to two? How does widening the box affect the tuning?
I am currently planning on using my Boston Acoustics GTA-800M amp for 800W RMS @2ohm. Be it a single 750-800W sub, two 400W subs, or 3 250-300W subs. If need be I will buy a new amp. I listen to mostly rock, metal, and EDM.
The drivers I'm looking at are automotive class but meet the requirements:
JL Audio 10W1v3-2: 11mm XMax, Fs 25.23 Hz, Vas 44.15L, Qts 0.436, 300WR/600WP $250
Alpine R2-W10D2: 20mm XMax, Fs 31Hz, Vas 18.2L, Qts 0.47, 750WR/2250WP $400 - NOTE, requires spacer on baffle as top mount depth is 5.92" if I used a 1/4" riser ring would the 20mm excursion be more of a problem?
Kicker CWR102: 17.5mm XMax, Fs 33.1Hz, Vas 26.38L, Qts 0.473, 200-400WR/800WP $136
Hertz MPS 250 S2: 16.8mm XMax, Fs 28Hz, Vas 24.5L, Qts 0.41, 500WR/1000WP $500
Cerwin Vega V102DV2: 17mm XMax, Fs 29.1Hz, Vas 39.6L, Qts 0.469, 400WR/1100WWP $130
Earthquake Sound Subzero-10: 31.75mm XMax, Fs 28.72Hz, Vas 30.67L, Qts 0.472, 750WR/1500WP $600 - something tells me the xmax alone is an issue, then I would need a 3/4" riser as the sub is 6 1/2". Is there a way to increase the chamber size?
This one doesn't meet T/S params but is intriguing: Earthquake Sound TNT-10S: 50.8mm XMax, Fs 35Hz, Vas 18.06L, Qts 0.624 (booo!) 300WR/1000WP, $107.
Re: Autotuba questions - drivers and box width
The width range for one driver is 15 to 20 inches, so the range for 2x10 is 30 to 40 inches. There's nothing to be gained by using a third driver. There is also nothing to be gained spending big bucks or having to make modifications using auto sound drivers that are optimized for use in a small sealed enclosure. They have massive xmax because in a small sealed box they have to. You also won't need more than 100w per driver. Most of the time you won't be exceeding 50w. Whatever you've read or experienced with direct radiating speakers doesn't apply to a horn.
Wingnut601
So the Dayton DCS255-4 is an ideal subwoofer. What effect does the wider box provide? I seem to recall reading that going to a wider box lowers the output frequency. Is that correct or am I mistaken?Bill Fitzmaurice wrote: ↑Wed Mar 04, 2026 11:22 am The width range for one driver is 15 to 20 inches, so the range for 2x10 is 30 to 40 inches. There's nothing to be gained by using a third driver. There is also nothing to be gained spending big bucks or having to make modifications using auto sound drivers that are optimized for use in a small sealed enclosure. They have massive xmax because in a small sealed box they have to. You also won't need more than 100w per driver. Most of the time you won't be exceeding 50w. Whatever you've read or experienced with direct radiating speakers doesn't apply to a horn.
Wider increases sensitivity at the bottom end of the horn's frequency range. It does not change the "tuning frequency".
I'd consider four eights if it pencils out. I originally planned on four eights, two in each 20" wide cab to fit between the wheel wells of my Jeep Cherokee. But, after building the first cab of two eights, I never built the second cab... it was enough output for me to not make it worth the time to build the second one. Not that I didn't want more output. Who doesn't, especially when it this clean and luscious? It just wasn't worth my time to build another one at that point. Maybe I shoulda done like you and went 40" wide right outta the gate.
No issue with two ten's. You'll be very happy. Just mention the eight inch option for the sake of options.
Wingnut601
Seth wrote: ↑Wed Mar 04, 2026 11:50 am Wider increases sensitivity at the bottom end of the horn's frequency range. It does not change the "tuning frequency".
The factory amp puts out 46W @2ohm per lead, 4 leads for the 12x8 quad vc sub. Cant find a 2ohm driver that looks like it'll work with the factory amp. That would be great to run 4 2ohm 8's or 2 4ohm (2ohm DVC) subs.Bill Fitzmaurice wrote: ↑Wed Mar 04, 2026 11:22 am The width range for one driver is 15 to 20 inches, so the range for 2x10 is 30 to 40 inches. There's nothing to be gained by using a third driver. There is also nothing to be gained spending big bucks or having to make modifications using auto sound drivers that are optimized for use in a small sealed enclosure. They have massive xmax because in a small sealed box they have to. You also won't need more than 100w per driver. Most of the time you won't be exceeding 50w. Whatever you've read or experienced with direct radiating speakers doesn't apply to a horn.
Wingnut601
Just ordered my flatpack box, 34" wide, from Speaker Hardware.
Going with two 8" Image Dynamic ID8D2 V4 drivers. Being that I have a quad voice coil sub currently I can simply pull all four connections and run one lead to each voice coil on the 8's, so 2 per driver. that gives me 48W per voice coil so 96W per driver and I'm still pulling the same power from the factory amp so there's no loss. That said, I should still make sure the length of each connection stays the same so there's no risk of delay, right? Or this not significant enough to worry about? Oh, the driver is only $99 and available direct, through dealers, and on Amazon. The dual 4ohm Qts is too high along with the 2/4ohm 10" drivers. So only their 8" dual 2ohm ID8D2 V4 driver is compatible. No other sizes or models will work.
Specs:
Nominal Impedance: Dual 2Ω
BL: 7.46
Inputs: DVC
Height: 4.45"
Width: 8.4"
Depth: 4.45"
Voice Coil Size: 1.5"
Material: Poly Cone
Magnet Size: 90 oz.
Dimensions (in Inches): 8.4"
Cutout Diameter: 7.125"
Mounting Depth: 4.45"
Xmax: 12.5 mm
Spl: 84
No: 0.143%
Qts: 0.463
Qes: 0.523
Qms: 4.008
Mms: 78.64
Cms: 294
Vas: 26.01
SD: 240.6
Fs: 31
Test Impedance: 1.9 - Tested Individually
VC Impedance: 2
Sensitivity: 84
Frequency Response: 30-500Hz.
Power Handling (RMS/Peak): 150W / 300W
https://imagedynamicsusa.net/us/en/prod ... D8D2-V4-1/
Specs:
BL: 7.46
Inputs: DVC
Height: 4.45"
Width: 8.4"
Depth: 4.45"
Material: Poly Cone
Magnet Size: 90 oz.
Xmax: 12.5 mm
Spl: 84
No: 0.143%
Qts: 0.463
Qes: 0.523
Qms: 4.008
Mms: 78.64
Cms: 294
Vas: 26.01
SD: 240.6
Fs: 31
VC Impedance: 2
Sensitivity: 84
An electron wave passes through wire at 0.7 times the speed of light.Wingnut601 wrote: ↑Tue Jul 21, 2026 10:15 pm should still make sure the length of each connection stays the same so there's no risk of delay, right?
Bill Fitzmaurice wrote: ↑Wed Jul 22, 2026 6:52 amAn electron wave passes through wire at 0.7 times the speed of light.Wingnut601 wrote: ↑Tue Jul 21, 2026 10:15 pm should still make sure the length of each connection stays the same so there's no risk of delay, right?![]()
Wingnut601
I'm just thinking of high end home theater systems where you have to set delays because of cable length.Bill Fitzmaurice wrote: ↑Wed Jul 22, 2026 6:52 amAn electron wave passes through wire at 0.7 times the speed of light.Wingnut601 wrote: ↑Tue Jul 21, 2026 10:15 pm should still make sure the length of each connection stays the same so there's no risk of delay, right?![]()
Nope....that's BS too. Don't listen to the oddiophiles. It's all snake oil to get you to buy expensive stuff that's no better than the cheaper stuff.Wingnut601 wrote: ↑Wed Jul 22, 2026 8:56 amI'm just thinking of high end home theater systems where you have to set delays because of cable length.Bill Fitzmaurice wrote: ↑Wed Jul 22, 2026 6:52 amAn electron wave passes through wire at 0.7 times the speed of light.Wingnut601 wrote: ↑Tue Jul 21, 2026 10:15 pm should still make sure the length of each connection stays the same so there's no risk of delay, right?![]()
Even with a 1000 foot cable the time taken for an electron wave to pass is around .000001 seconds. AFAIK no one makes a delay with that level of adjustment.
Delay is set on surround systems due to physical distance of speakers to your ears, not because of cable length.Wingnut601 wrote: ↑Wed Jul 22, 2026 8:56 am I'm just thinking of high end home theater systems where you have to set delays because of cable length.![]()
You want the appropriate sounds arriving from your speakers at the same time and not everyone has the perfect room layout for the kit. Say for example you have the left front speaker next to the TV but need to have the right front further away for room constraint issues. You'd tell the AV receiver the distance of all speakers to where you're sat and whenever the receiver is playing audio balanced between the front L/R speakers, it will add delay to the closer speaker (left front in this case) to ensure the audio signal reaches your ears at the same time. It's a small thing but it works very well in keeping the clarity in your audio, delayed audio can sound really weird and incoherent depending on the distances involved.
