Behringer X32 Rack to Replace dbx Driverack 260 +Behringer XR18?
Joman116
#1 Post by Joman116 »
Hey everyone,
I’m a sound tech and part-time DJ. Last year, I picked up a used dbx DriveRack 260 mainly to handle hard limiting for my passive sub amp, and it’s been useful for its feedback suppression as well.
I also recently got a Behringer XR18 with a GL.iNet Slate router—my first digital mixer. I’ve been using it for live bands and ceremonies, and overall it’s been pretty impressive.
That said, I’m starting to notice some overlap in what these two units do. I’m thinking about simplifying my setup by replacing both with a Behringer X32 Rack. I understand it doesn’t have built-in automatic feedback suppression (so I’d have to manage that manually through EQ), but it seems to offer a lot more flexibility and capability compared to the XR18. From what I gather, it covers everything the XR18 does and then some.
I’ve also noticed more X32 units popping up for sale as people move to the Wing Rack, which makes it feel like a good opportunity to make the switch.
Curious to hear your thoughts or experiences—does this seem like a smart move?
Edit : I don't think the X32 has crossover functionality which is critical for bfm Subs
Edit2: Thanks all for the responses. I think the direction I will go is to KEEP the DBX 260. The x32 doesn't really have the intended function to replace it.
QSC 1804 Amp
Re: Behringer X32 Rack to Replace dbx Driverack 260 +Behringer XR18?
#2 Post by Bruce Weldy »
Keep the driverack. You need the dedicated crossover and limiting. Even if the mixer could do it all, you would still stand the chance of changing to a scene that doesn't have the proper processing and blow it all up. Not worth the chance.
But, I don't think the mixer can do the brickwall limiting you need to protect the subs.
Joman116
#3 Post by Joman116 »
Bruce Weldy wrote: Wed Apr 01, 2026 8:19 am Keep the driverack. You need the dedicated crossover and limiting. Even if the mixer could do it all, you would still stand the chance of changing to a scene that doesn't have the proper processing and blow it all up. Not worth the chance.
Gotcha, appreciate the insight.
QSC 1804 Amp
#4 Post by Seth »
Bruce is right.
I absolutely love the XR18 and I'd only recommend you step to a X32 if you are running out of inputs on the 18. I had one show I did that used every single input of the XR18, so I bought a 32 channel... never used more than 18 channels... spent money I didn't need to spend. There's not really too much the X32 does that the XR18 won't, other than inputs. There's a few things, but core functionality and capabilities are the same.
As far as using either of them in leu of a Driverack, they do have crossover capability and EQ capability, but what they don't have is a proper brick wall limiter on the output's. There might be a creative signal routing solution to use a channel's compressor as a limiter. But, it's a work around, not the professional and dedicated solution your system requires. 100%... keep the DriveRack and don't get the 32 unless you need the inputs.
Joman116
#5 Post by Joman116 »
Seth wrote: Wed Apr 01, 2026 10:14 am Bruce is right.
Appreciate the reply. The XR18 is fantastic. It really grew my business, but now I am running into situations where I've been asked if I had X32 experience, my answer is "sort of" as its similar to the XR18.
The X32 is the gold standard in the segment for even larger shows in my area..and I do like the fact that it has a small screen attached to it. I'm able to sell my xr18 at almost the same price I bought it for ($500) .and think i can snag a used x32 in the $700 range...
QSC 1804 Amp
#6 Post by Bruce Weldy »
Joman116 wrote: Wed Apr 01, 2026 3:30 pm
Are you considering an X32 or an X32 Rack? Two different animals. The X32 has 32 inputs. The X32 Rack does not. It only has 16 inputs on the unit. You'd have to add a stage box to get more.
I just used the M32 Rack Monday night (same thing but the Midas version). The guy that had set it up was using the EQs to create a crossover to utilize aux-fed subs. Personally, I think it's a bad idea as 90% of the bands that come through there don't have a sound man or know how to use that system. I would rather see them use the built-in crossovers in the powered EV speakers and subs than the aux-fed approach as few actually understand how to use it. In fact, I would have suggested an analog board for their situation to make it all idiot-proof......although, even that can be screwed up. :D
While I'm a Presonus guy and use the R32 rack mixer for my sound shows, when I play my duo show - like I did Monday, I use an XAir12. Then plug direct into the speakers, or in this case - two channels of the M32 Rack.
Joman116
#7 Post by Joman116 »
Bruce Weldy wrote: Wed Apr 01, 2026 4:27 pm
*Referring to X32 RACK
QSC 1804 Amp
#8 Post by Bruce Weldy »
Joman116 wrote: Wed Apr 01, 2026 4:40 pm
In that case, you'll get no extra inputs without an additional stage box.
Joman116
#9 Post by Joman116 »
Bruce Weldy wrote: Wed Apr 01, 2026 4:52 pm
Acknowledged, my prerogative is not more inputs..its getting more familiarity with this x32 platform standard.
QSC 1804 Amp
#10 Post by Seth »
Joman116 wrote: Wed Apr 01, 2026 4:57 pm
If you're using a tablet, phone, or PC as your interface, it's essentially the same, nothing to familiarize yourself with. However, the X32 Rack shares the same hardware user interface as the console (short of all the sliders and some other knobs)... which the XR18 obviously doesn't have. It's really not a bad idea to learn what you want to learn. I've always used my PC or phone as the primary interface, but I haven't been in a position to step in front of a X32 console without the interface I'm used to working with. Although I'm sure I could figure it out, just wouldn't be muscle memory the way I am in the app based interfaces.
#11 Post by Bruce Weldy »
Seth wrote: Thu Apr 02, 2026 9:22 am
He's right....
The Behringer app is pretty much the same for the XAir and the X32. And using the X32 app won't help you a bit as far as getting in front of the X32 console. Save the money.
If anything, spend a few bucks on the Mixing Station app. Then it will be the same regardless of the platform that you're on....or, at least really close. A lot of guys swear by it. The Berry platform is a bit of a pain anyway. I still use it simply because I don't mix on that platform a lot and I can get around with the Berry app....but, if it was my main mixer, I'm pretty sure I'd start using Mixing Station.
Strange Kevin
#12 Post by Strange Kevin »
Hope this thread isn't too dead yet.
For the original question, I'd keep the drive rack just for the security of making it harder to accidentally change the settings.
I use both Xair and X32 on a regular basis.
My main system is the Midas M32C with DL32.
Most things are going to be similar. Especially if using Mixing station. (Highly recommend)
Biggest benefit for me with the X32/M32 is more outputs and the extra FX channels are nice. Also you get the matrix sends and a few more buses to play with.
It depends on the the type of shows your are currently doing or would like to be doing soon.
Having both systems can be nice if I'm doing a wedding. Setup the Xair with a wireless mic or two for the ceremony , then the x32 outside with the band for the reception party or whatever.
Last nigh I was working with a 10 person band and while I still only needed 16 inputs, I would have ran out of outputs with the Xair. (Or even the X32 rack without an extra stage box - only 16inx8out on the back)
Tonight I'm at a venue with a Xair18 installed.
The 8 outputs are just enough for 4 monitors, a send for the patio speakers, Sub, LR.
Sometimes I could really use 5 or 6 monitors here but I rarely need all the inputs.
Joman116
#13 Post by Joman116 »
Strange Kevin wrote: Sat Apr 11, 2026 1:44 am Hope this thread isn't too dead yet.
Kevin, appreciate the reply. Yes definitely decided to keep the driverack.
My business is growing so I think it makes sense to move to the X32 rack and get comfortable with it. It's the default mixer so many people /venues have. I'm seeing it for $799 new at Many retailers so hopefully I can snag a used one for a gee hundred less.
I was tempted by the new behringer Wing Rack, looks great, the touch screen looks sweet, but still a bit expensive for me to justify at $1799. I know alot of folks are upgrading their X32 for the wing. I'll likely jump on it once it becomes more prolific, and mfring has worked out whatever issues that may exist.
QSC 1804 Amp
Zippie
#14 Post by Zippie »
Just a thought to throw out concerning options for limiting and crossover on the X32/M32 platform.
There was a mention of crossover at the matrix level on these.
They do have very steep HP-LP filters that are crossover intended I believe the BW24db/octave is the steepest. Much more slope than the standard EQ HP or LP give you on a channel or mixbus. They are only available at the matrix level.
It’s not like a traditional crossover that gives you a high and low output from a single input.
Essentially you send the same signal to 2 separate matrices then HP one and LP the other.
In the event of an aux fed sub setup you would send mains to a stereo matrix with HP and the sub mixbus to a mono matrix with the LP, also could place a low HP wherever you want in the 30-40 hz range to protect the bottom end of the signal as well.
There is a hard limiter if I’m not mistaken in the FX rack called Precision Limiter that is considered a brick wall style, I have not personally tested it. It can be applied at the matrix level as well.
Understanding this is also before any amp settings and would need to be used with caution.
There is also a parameters safe setting in the console that will lock certain features so when a scene is recalled it can’t override the current settings. This would be good for the limiter and crossovers given consistent amp/speaker setup.
I wouldn’t just throw it out for any random person to run with, but I would be comfortable setting things to a preference and being able to keep it with the X32 in the absence of a drive rack in a pinch.
That being said, if I had a drive rack, I’d probably keep it.
Without a drive rack:
I’d recommend dialing in system tuning on the matrix level as the end of the signal chain before amps, then back up to the mains channel for any room EQ correction. This allows you to always have the system tune and limits preserved in the console for a given PA via the matrix level.
Kinda gives the separation of the drive rack within the console before it outputs.
Hope this is helpful.
#15 Post by Bruce Weldy »
With standard front loaded subs, what you described will work. I'd be very cautious though, trying to limit with the board....too much chance for error. You'd have to start from a master scene every time to ensure that your limiter parameters carry forward. One little mistake and your folded horn subs are toast. If I have a big enough system to be using an X32, I'd spring for a driverack....even a used one. Then you know your system is protected regardless of what is hooked up on the front end.
