I've always used 3/4" brads - set to the deepest setting. 1" can go through two thicknesses of ply. Plenty of hold while the PL dries.
First BFM Build Odyssey: Tuba 60
Re: First BFM Build Odyssey: Tuba 60
All right folks I have returned. I test fitted the driver and installed it with the recex screws. I ran the 20 Hertz test tone. There's a lot of vibrations so it's really quite difficult to determine if the speaker cone surround is hitting the baffle. The sounds that I hear are either the piece of wood or the table vibrating I believe. Visibly I don't really see it touching.
Won't be getting around to next steps till beginning of June.
QSC 1804 Amp
QSC 1804 Amp
Did you try the trick of coating the roll with chalk, and then trying it?
I put the order in yesterday so the chalk should arrive today. I was trying to avoid buying another piece of apparatus but don't want to screw this up.
QSC 1804 Amp
QSC 1804 Amp
