TLAH or SLA PRO for a church
Short and Transmission Line Arrays for Pros
Mbranzuela
Re: TLAH or SLA PRO for a church
#16 Post by Mbranzuela »
Driver question for titan 39. We are going with a pair of 12 inch drivers for 2 separate cabinets. These are going in a small church 40 x 60 or about 2,400 sq feet permanently fixed mounted.
My question is on what drivers to order. Choices are: Delta 12lfa, Kappalite 3012 lf, lab 12 and s2012. Also, there are some Eminence Impero 12a Pro at a discount.
please advise. Also, please comment if you think 2 cabinets are too much. These will be running with a pair of SLA pro with 4 drivers.
#17 Post by Seth »
3012LF
#18 Post by Bruce Weldy »
Mbranzuela wrote: Wed Jan 21, 2026 1:52 pm Driver question for titan 39. We are going with a pair of 12 inch drivers for 2 separate cabinets. These are going in a small church 40 x 60 or about 2,400 sq feet permanently fixed mounted.
2 cabs with 3012LF.
Before you permanently mount them - be sure to learn about proper sub placement.....it truly makes a difference.
#19 Post by Seth »
Bruce Weldy wrote: Wed Jan 21, 2026 7:56 pm Before you permanently mount them - be sure to learn about proper sub placement.....it truly makes a difference.
+1
Sub placement in a room can make or break an otherwise well thought out system.
Please feel free to ask placement questions if you have them. What you think it "should look like" is, in many many MANY cases, the worst place to put them.
#20 Post by Bill Fitzmaurice »
Yep. Subs are like real estate. What matters most is location, location and location.
Mbranzuela
#21 Post by Mbranzuela »
Is there a section / tutorial in the forum that describes proper sub placement?
#22 Post by Bill Fitzmaurice »
Good thing it's not a snake. viewforum.php?f=10
Mbranzuela
#23 Post by Mbranzuela »
Thanks for the link Bill, apparently, my wife uses the same snake comment. Also, I learned there is a plethora of misinformation about sub placement on the internet, - thanks for the link. The facility is a small church - 2400 sq feet. Due to space constraints, it seems like the best option will be one larger T39 as opposed to to two smaller sub's poorly located. What seemed like a good spot for the second sub is definitely not good ( on the same state about 15 feet apart). One potential good spot for the 2nd sub would require removing some seats. Again, thanks for the info!
#24 Post by Bruce Weldy »
Mbranzuela wrote: Fri Jan 23, 2026 1:32 pm Thanks for the link Bill, apparently, my wife uses the same snake comment. Also, I learned there is a plethora of misinformation about sub placement on the internet, - thanks for the link. The facility is a small church - 2400 sq feet. Due to space constraints, it seems like the best option will be one larger T39 as opposed to to two smaller sub's poorly located. What seemed like a good spot for the second sub is definitely not good ( on the same state about 15 feet apart). One potential good spot for the 2nd sub would require removing some seats. Again, thanks for the info!
Why can't you put the subs side-by-side? If there's a stage, they can lay down in front of the stage. Or, they could be corner loaded, wall-loaded, etc. There are a lot of options.
Mbranzuela
#25 Post by Mbranzuela »
Hi Bruce,
Problem is stage is small so there is space for one t39. Also, the entire church room is 2400 sq ft. There isn't room in the stage corner for two t39's. The optimum spots would require removal of seating.
Instead of two 20 inch t39's we will try 1 24 inch cabinet. It will still be light years better than the current setup.
#26 Post by Seth »
A little outside the box thinking for ya, food for thought... subs don't have to be on the floor nor in the front of a room. Properly bracketed and anchored into studs/concrete/brick, they can be mounted on a wall against the ceiling and be painted to match the wall color. If you have a drop ceiling, they can be mounted completely out of sight in the space above the ceiling tiles. These options eliminate taking up floor space and minimize visual impact. Many times, even mounted in a rear corner of a room (ceiling or floor) can provide excellent results too.
#27 Post by Bruce Weldy »
Mbranzuela wrote: Thu Jan 29, 2026 12:27 pm Hi Bruce,
I'm not talking about putting the sub on the stage, but in front of it. You really don't want it on the stage. So, in front or to the side. If the stage is kinda' low, you can build two narrow subs that laying down will be the same height as the stage as long as it's at least 14 inches high.
