Hey guys! Long time no type. Hope all is well in your respective neighborhoods...
As the header says, is the RCF L15s801 Subwoofer a good candidate for the BFM T48? Specs are as follows.
Fs: 48Hz
Qts: .32
Xmax: 6mm
RCF L15s801 for the T48?
- tribal king
Re: RCF L15s801 for the T48?
Nope....not enough xmax if you want to give it some power.tribal king wrote: ↑Sun Dec 07, 2025 2:31 pm Hey guys! Long time no type. Hope all is well in your respective neighborhoods...
Fs: 48Hz
Qts: .32
Xmax: 6mm
- tribal king
Ok what about the PRV 15w1000v2 specs?Bruce Weldy wrote: ↑Sun Dec 07, 2025 7:20 pmNope....not enough xmax if you want to give it some power.tribal king wrote: ↑Sun Dec 07, 2025 2:31 pm Hey guys! Long time no type. Hope all is well in your respective neighborhoods...
Fs: 48Hz
Qts: .32
Xmax: 6mm
Fs: 39Hz
Qts: .68
Xmax: 6.37
The recommended drivers in the plans are at 9.6 (Emimence 3012LF)and 11.8 (Lab 15) xmax. I didn't check to see if the other parameters match. Do you have the plans? It has all of the T/S parameter specs and ranges.tribal king wrote: ↑Mon Dec 08, 2025 7:21 am Ok what about the PRV 15w1000v2 specs?
Fs: 39Hz
Qts: .68
Xmax: 6.37
"Ok what about the PRV 15w1000v2 specs?"
If you want big bang for your buck this is the PRV most in here refer to:
https://www.parts-express.com/PRV-Audio ... quantity=1
