Jack 15 Lite Build
Benflitv30
Jack 15 Lite Build
#1 Post by Benflitv30 »
Finally getting around to building this cabinet since inquiring here a long bit ago about it being the best single cab for tailgating purposes.
Firstly, I am humbled by my woodworking skills, or lack thereof. Have only built the 36” THT and general vented MDF car audio style cabs in the past. I understood the difficulty rating was higher than other designs Bill has, but you don’t grow in your comfort zone.
The hardest part has been forming the throat sheaths followed by the horn sheaths as witnessed by all my missed staple shots. I used my commercial steamer to try and pre-form the panels (verified grain/flex direction) before installation which seemed to help a lot.
Side note - I do think I need to invest in a better table saw fence, framing square, and tape measure. 😂😂
Re: Jack 15 Lite Build
#2 Post by Bill Fitzmaurice »
:hyper:
Benflitv30
#3 Post by Benflitv30 »
- I did scratch my head on getting the woofer centered just right on the woofer spacers, measuring many times and adjusting. Still not perfect, as seen in horn facing photo. The bottom right corner of baffle/woofer, there is more surround showing. Any advice with this part? Thank you!
- On the next build, I think it’d help me to draw out the lines on the sides and baffle for the horn braces before assembling the sides and top of cab.
- Cutting the foam ball for the dome extension with a ‘hot knife’ designed for foam made it a breeze versus using a saw of sorts.
#4 Post by Bill Fitzmaurice »
The driver doesn't need to be perfectly centered, so long as the gasket seals all around and the screws aren't close to the edge of the spacer. Put it place, mark through the frame holes to be sure before finalizing the position.
Benflitv30
#5 Post by Benflitv30 »
Thank you, Bill. I didn’t know if it would change much in ‘compression’/ linearity of the woofer being off center of that phase plug extension.
Is there any tip on how to form and fasten the sheaths easier? Just lots of clamps? Haha.
Going to do one of the PE/Dayton amp modules for this cab. The one I’m looking at has DSP. Is there a low cost of entry way to measure response to determine where to make EQ adjustments? Any predetermined range where the J15L likely would need adjustment for outdoor use?
Link to amp here -
https://www.parts-express.com/Dayton-Au ... SP-325-434
#6 Post by Bill Fitzmaurice »
This is adequate for non-critical measurements: https://play.google.com/store/apps/deta ... yzer&pli=1
Keryn O'Shea
#7 Post by Keryn O'Shea »
Benflitv30 wrote: Tue Jan 02, 2024 10:35 am ..I am humbled by my woodworking skills, or lack thereof..
Looks like you're doing an excellent job on a cracking cab mate!
Benflitv30 wrote: Tue Jan 02, 2024 10:35 am Have only built the 36” THT
Only..😳
Benflitv30 wrote: Tue Jan 02, 2024 10:35 am ..you don’t grow in your comfort zone.
Absolutely 👌
This is for bass, yea? No HF?
AT8 14", AT10 19", T30 28" LAB12, T48 36", THT 20", SLA 4x3"/4x4", CArray 6x4", TLAH, TLAP, J10 FA, J12 FA, OT8 CD, OT12 FA, OT15 CD, SLAP 2x6"/4x6", WH6 PA, WH8 MA, WH10 CD, DR280 MA, XF210.
9830Lark
#8 Post by 9830Lark »
I used a laser engraver to 'score' the smaller ones so they'd bend easier. Worked great.
https://billfitzmaurice.info/forum/view ... 66#p291266
Strange Kevin
#9 Post by Strange Kevin »
At least for the side sheathing, I remember a couple well placed ratchet straps can help hold em in place.
Also might try leaving the sheathing in a 5 gallon bucket or similar overnight to get some pre-bend into the wood so you're not fighting it as much when you go to install them.
howiez
#10 Post by howiez »
Looking great!
Benflitv30
#11 Post by Benflitv30 »
Bill Fitzmaurice wrote: Thu Jan 04, 2024 10:21 pm This is adequate for non-critical measurements: https://play.google.com/store/apps/deta ... yzer&pli=1
Thank you, Bill!
Benflitv30
#12 Post by Benflitv30 »
Keryn O'Shea wrote: Sat Jan 06, 2024 3:16 am
Only..😳
Absolutely 👌
I appreciate the kind words. I love the big THT. I don’t have a sliding or French doors in this house which made it a fun time with the door trim getting it inside. Haha!!
This Jack15L will have the 20 melded tweeter array. Going to put the 3-way switch on the tweeters for versatility in listening environments. All those tweeters I’m sure will come in handy on a boating day out on a wide open sandbar. Otherwise will be used for tailgating at games and bbq’s etc. 💪🔥
Benflitv30
#13 Post by Benflitv30 »
9830Lark wrote: Sat Jan 06, 2024 7:52 am
That’s a great tip. Basically kerfing the panel. Thank you.
Benflitv30
#14 Post by Benflitv30 »
Strange Kevin wrote: Sat Jan 06, 2024 10:15 am At least for the side sheathing, I remember a couple well placed ratchet straps can help hold em in place.
Do you mean strapping the panel to the outside of a 5 gallon bucket? That makes sense to me.
I followed the plans with the wood grain going in the right direction along with the wax papered brace against the baffle holding the horn and throat sheaths tightly to allow bending. It just seemed much harder to bend than I expected, especially the throat sheaths being that they are smaller.
Benflitv30
#15 Post by Benflitv30 »
howiez wrote: Sat Jan 06, 2024 11:10 pmLooking great!
Thank you!
