OmniTop 12 build
Fastskiguy
OmniTop 12 build
#1 Post by Fastskiguy »
The journey starts! This isn't gonna be fast but hopefully we'll make it all the way :)
Clef's of Bass
Re: OmniTop 12 build
#2 Post by Clef's of Bass »
layout looks good!
#3 Post by Tom Smit »
Enjoy your journey!
I have the same earmuffs at work. I like them.
Clef's of Bass
#4 Post by Clef's of Bass »
Tom Smit wrote: Tue Jan 24, 2023 10:45 pm Enjoy your journey!
I use the 3M muffs. Has AM/FM and bluetooth. They get a lot of use during garage/ shop time and yard work.
Fastskiguy
#5 Post by Fastskiguy »
I was hesitant to share this picture because it will make any flaw completely unacceptable given the equipment I was able to access....but what the heck, I'm a beginner. Main panels are cut!
#6 Post by Seth »
:clap:
CarterKraft
#7 Post by CarterKraft »
Very nice
Weldon Carter
jimbo7
#8 Post by jimbo7 »
Compression drivers or tweeters?
Fastskiguy
#9 Post by Fastskiguy »
I'm gonna try for that cross firing tweeter array. I made two TLAH and two SLAs so wiring them up should be not terribly different. At least that's the current plan!
Joe
Fastskiguy
#10 Post by Fastskiguy »
Is the jigsaw the thing to use cutting out the baffle? Mine tore the crap out of the plywood.....it was a mutiliation. I'm going to give it a bit of bondo or something but whoa! Maybe it's a blade issue? I just used whatever I found rattling around at the bottom of the case, not sure what it was made for (It looked sharp)
#11 Post by Tom Smit »
A jig saw can be used. A fine-toothed blade will produce better results but will take longer to make the cut, as opposed to a coarse tooth blade. What a bunch of people do is cut about and 1/8" away from the cut line, and then use a powered router to bring the cut to the line by using a guide.
Fastskiguy
#12 Post by Fastskiguy »
Spent some time making a couple of router jigs for circles. These worked pretty well.
Fastskiguy
#13 Post by Fastskiguy »
Tom Smit wrote: Sat Jan 28, 2023 1:10 am A jig saw can be used. A fine-toothed blade will produce better results but will take longer to make the cut, as opposed to a coarse tooth blade. What a bunch of people do is cut about and 1/8" away from the cut line, and then use a powered router to bring the cut to the line by using a guide.
Ah now that is a good idea, thanks :)
Fastskiguy
#14 Post by Fastskiguy »
Making faster progressed than planned and...for the most part...it's going well. But the baffle....oh boy, I'm looking forward to taking another crack at this someday on speaker #2. I have a question about the little lip that is shown in the arrows below...should I take a rasp or file or something and trim back the baffle until it is flush with the horn panels and throat reflectors or is that lip OK? Thanks guys :)
Joe
That lip is far too small to have any effect. Anything less than a quarter wavelength in dimension is invisible to sound waves. A quarter wavelength at 2kHz is 1.9 inches.
