CarterKraft
#166 Post by CarterKraft »
CarterKraft wrote: Wed Oct 05, 2022 11:14 am I was thinking something like you suggested Seth, possibly rotated more towards the South but in that corner is fine for me, it is open for a long way behind that tree line.
I will take more video for sure, the videos were taken by my son who has a totally different video style than myself.
This is a satellite view to help with some scale. I have plenty of schools with large open parking lots but I am not sure if I can get a better/lower noise floor at them. I will set up here and give it a run, if I run into problems I'll find a new location.
I tried to set this up Saturday but the wind (I forgot about that LOL) had a 90db noise floor during gusts so it was aborted.
Weldon Carter
#167 Post by Bruce Weldy »
CarterKraft wrote: Wed Jan 18, 2023 9:37 am
Bruce Weldy wrote: Thu Sep 29, 2022 10:24 am
CarterKraft wrote: Thu Sep 29, 2022 8:28 am
I also realized I skipped the dampening foam (I guess I got too excited) so I need to revisit that.
You need to do that before any more testing.
I found a new 1.5" to 2" foam mattress topper when cleaning up recently. I currently have quilt batting stapled in the cabinet, would it be worth it to swap the batting for the mattress topper foam when I pull it down again to duratex?
I would.
CarterKraft
#168 Post by CarterKraft »
Good deal, I will put that on the to-do list.
Thank you
Weldon Carter
#169 Post by Bill Fitzmaurice »
There's no advantage to foam over polyester batting when they're of equal thickness.
CarterKraft
#170 Post by CarterKraft »
The batting is much thinner really in my installation.
It would take another layer I bet to get equivalent thickness.
Weldon Carter
CarterKraft
#171 Post by CarterKraft »
Worked on the final details today. I bought a corner handle that I thought was going to be perfect but evidently I can't read a tape measure and it is sized perfectly for a toddler...
I did what I had planned on doing originally, build a handle from 3/4 EMT and wood. This was a little more challenging than I thought, but in the end it came out awesome.
I'm working on a 2 LED, aux input panel for the front and a rear panel with power source selection switch, AC input power jack and a GX16 aviation connector for the DSP programmer.
Both panels will be inset 1" with proper 3/8" radius on the cutout.
I am still thinking about adding dynamic bass knob, but it might get hidden somewhere, I have learned that people like to turn knobs when presented with the opportunity.
As usual pix are sideways but will be correct when clicked.
Weldon Carter
#172 Post by Tom Smit »
I'm glad you got the "up"...."side" right, LOL. Anyway, well done... you did a great job.
CarterKraft
#173 Post by CarterKraft »
I promise I'm gonna get the pix situation figured out before this is over 🤦
Weldon Carter
#174 Post by Tom Smit »
Tom Smit wrote: Mon Jan 23, 2023 10:25 pm I'm glad you got the "up"...."side" right, LOL. Anyway, well done... you did a great job.
In case I got misunderstood, I meant the pocket for the grab handle.
CarterKraft
#175 Post by CarterKraft »
Tom Smit wrote: Tue Jan 24, 2023 10:43 pm
Trust me I had a few OH S*** moments where I wondered if I had done just that. :loler:
Weldon Carter
CarterKraft
#176 Post by CarterKraft »
My laser cut logos came in so I will get back on this project tonight, I really need to get it wrapped up.
Weldon Carter
CarterKraft
#177 Post by CarterKraft »
Got the LED, aux port installed. I'll paint the aluminum plate before permanent installation and glue it in with some silicone.
Phase one of the logo is installed, this is a thin piece of plywood around 1/8" hopefully I can make it look good when it gets duratexed. I haven't decided exactly how I am going to handle that just yet.
Weldon Carter
CarterKraft
#178 Post by CarterKraft »
Got the rear panel installed. Power button selects battery or 5.5mm power port for AC power brick. The 6 pin GX16 connection is for the KPX programmer to the DSP chip so it can be remotely programmed with out having to open the cabinet.
Weldon Carter
CarterKraft
#179 Post by CarterKraft »
First coat of duratex, I'm gonna love this stuff I think.
Weldon Carter
#180 Post by Seth »
I really like how that logo looks, as is.
