I wondered about how to drill. I'll try the Dremel approach. That makes great sense.
Of loose screws and piezo glues...
Re: Of loose screws and piezo glues...
1 x DR250
1 x T39
1 x Omni 10
1 x DR250
1 x T39
1 x Omni 10
I tried two ways. I bought a small container of MEK at my local big box home improvement store (in the paint section). I melted (dissolved) my array trimmings in a baby food jar with a few ounces of MEK for days. I kept stirring, and adding until I got the consistency I wanted. Then I slathered that in some of the holes with a toothpick. I also used it to butter the back side of my array to strengthen it. I also tried plumbers cement for ABS, which you can get in black, it works very nice as well. Takes a bit for either method to dry. The plumbers cement I'm sure is relying on a thin film in a tight pipe joint to weld the two together. Just dropping it in air in quantity seems to take time. Same for my MEK/ABS slurry. It takes a bit to cure and has to be done outside or in a well ventilated garage. That stuff stinks! Almost all of my array screws were loose after taking off the piezos for cutting/gluing/painting. I probably ended up putting something in almost every single hole.
When I build the next one, I probably won't remove the piezos, I'll tape like you did, and avoid painting them altogether.
