I have an abundance of 12" Poplar board that I joined 15 years ago that is 20" wide. Joints are solid and joined properly with any warping.
Is there any reason, other than a potential weight difference, that I can't use this to build my cabinet? I would still use plywood for the speaker baffles.
Using Solid Wood for XF210 or XF212
Re: Using Solid Wood for XF210 or XF212
I don't see any problem at all....
So......you are building a 2x12 cab and loading it with 10s, then you want to build it out of 3/4" solid wood.....hmmmm.....are you a weightlifter and this will be part of your workout?
I've decided to use the 12". It'll have wheels and I don't have to lift it. Though I could use to build some muscle mass in my old age!Bruce Weldy wrote: ↑Sun Mar 20, 2022 7:08 pm I don't see any problem at all....
Plus I can't find that plywood anywhere. Even the Baltic Birch is only available in 3/4" around here.
Imagine if the amp head was actually a combo with cab permanently attached.
Should be perfectly fine indeed. I remember a British niche brand that made very nice bass amps and cabs in solid wood. Could have been mahogany, not entirely sure. Poplar must be a fair bit lighter. It dents somewhat easily. The old back doesn't mind the lighter weight of poplar though.
Fender cabs used to have solid wood top, bottom and sides. Probably poplar, not because it was better, but because it was considered a junk wood because of its green streaks and therefore used to be cheaper than pine. But that was in the 50s-70s, when lumber wasn't farm grown. Pine grows faster, so it's probably cheaper now.
RunTheOtherWay
Well? Did you built it?AxeMan7 wrote: ↑Sun Mar 20, 2022 4:34 pm I have an abundance of 12" Poplar board that I joined 15 years ago that is 20" wide. Joints are solid and joined properly with any warping.
