Big amps
Is this amp OK?
DJStubbs
Big amps
#1 Post by DJStubbs »
So I don’t use my lab gruppen often because 30 amp plugs are not common enough in my opinion. But when I do it’s interesting.
So it’s 30 amp 110-230v which I have only used 110-120v.
My question is some generators I have seen that offer 240v twist connectors are 4 pole. The lab gruppen plm10000q has a neutrik 32 plug on it that is 3 pole. So how do I wire a 4 pole twist lock to give me 240v sufficiently. Also if I were to get a 50 amp plug off let’s say a generator could I wire that up to the lab gruppen as well?
18x Tuba 60 - Dual 12" LAB
6x Renkus Heinz ST6
6x Renkus Heinz CFX218
2x Renkus Heinz ct5212
1x Lab Gruppen PLM10000Q
2x QSC PLD4.5
2x QSC PLD4.3
Klarity Audio & Lighting
https://www.facebook.com/KlarityAudio/
CoronaOperator
Re: Big amps
#2 Post by CoronaOperator »
lab gruppen manual: http://downloads.labgruppen.com/PLM_Ser ... _Guide.pdf
Powencon assembly instructions: https://www.neutrik.com/en/product/nac3fc-hc
From the lab gruppen manual:
"The label adjacent to the mains (AC) input connector indicates the AC mains voltage for which the
device is wired and approved.
The PLM 10000Q and PLM 14000 devices are available in separate 115 V and
230 V versions; the PLM 20000Q is only available with a universal power supply operating from 80 to 265 V.
Only connect the mains cable (AC cord) to an AC source of the voltage shown on the label"
Unless things have changed, it seems like your amp can only handle EITHER 120V or 240V, whatever it was wired for from the factory. You can still use the 30 amp 120v receptacle on the generator.
DJStubbs
Re: Big amps
#3 Post by DJStubbs »
What’s a good step to be stable though and reduce the possibility of overloading the breaker. 30 amps isn’t much. I’ve seen my pld4.5s hit 25 amps With 4 channels thumping. So I’m sure this lab gruppen will pull a lot more power. I’ll check what mine says. I’m thinking of getting another distro made with a 50 amp inlet and 30 amp outs but How do companies run multiples of these lab plm amps sufficiently.
6x Renkus Heinz ST6
2x QSC PLD4.5
2x QSC PLD4.3
ka7niq
Re: Big amps
#4 Post by ka7niq »
I have a big Apogee Amp I seldom use much anymore, mainly because the fans are so noisy. I am running a bi amplified Peavey system, and my Horn requires CD Equalization. Currently I have a Mackie amp running the horn, and it has adjustable CD Equalization built in. Plus, it's fan noise is tolerable.
Apple Roof Cleaning Tampa Florida
711 Westbrook Ave
Brandon Florida 33511
Https://www.saferoofcleaning.com
Re: Big amps
#5 Post by Bruce Weldy »
ka7niq wrote: Thu Oct 21, 2021 11:04 am I have a big Apogee Amp I seldom use much anymore, mainly because the fans are so noisy. I am running a bi amplified Peavey system, and my Horn requires CD Equalization. Currently I have a Mackie amp running the horn, and it has adjustable CD Equalization built in. Plus, it's fan noise is tolerable.
I've never seen or heard of an Apogee Amp......never knew they made amps. Thought they did mostly recording interfaces. Is it really old?
himhimself
Re: Big amps
#6 Post by himhimself »
Hmmm, at first couldn't imagine why you'd need to tax an amp that size... then saw 18x Tuba 60 - Dual 12" LAB Oh yeah!!! Crank up the volts! I'd love you hear your system some day :-)
2xT30 (20", 3012LF)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
ka7niq
Re: Big amps
#7 Post by ka7niq »
Bruce Weldy wrote: Thu Oct 21, 2021 6:30 pm
Yes, it is older, not ancient.
711 Westbrook Ave
Re: Big amps
#8 Post by Bruce Weldy »
ka7niq wrote: Fri Oct 22, 2021 8:26 am
I tried searching for them, just to see 'em.....but, couldn't find 'em anywhere - even in Apogee's legacy products. Interesting.
Re: Big amps
#9 Post by Seth »
Need practice more google foo grasshopper
Ebay Listing
Another
Re: Big amps
#10 Post by Bruce Weldy »
Seth wrote: Fri Oct 22, 2021 12:30 pm Need practice more google foo grasshopper
I didn't see any ad listings pop up ...... so, I just checked the Apogee website. Thanks for the pics......I've never seen those....and I've seen a few amps in my time.
Did some more specific searching. Looks like these are really built for commercial installs. Lower power, binding post outputs only, and really expensive. They've just never popped up in my world of live sound.
Kinda' looks like Apogee and Apogee Sound International are different outfits. The amps line looks like they bought out Bogen and stayed in the commercial install world. Couldn't find any link between the two names.
Re: Big amps
#11 Post by Seth »
Yeah, I've never heard of Apogee at all before now. Completely new to me. Looks like they're somehow related to Bogen, which I have heard of... high end (well... expensive) install stuff.
Re: Big amps
#12 Post by Bruce Weldy »
Seth wrote: Fri Oct 22, 2021 6:01 pm Yeah, I've never heard of Apogee at all before now. Completely new to me. Looks like they're somehow related to Bogen, which I have heard of... high end (well... expensive) install stuff.
You are too young to remember the old Bogen PAs. We used one for our Senior talent show when I was in high school....That's it right down front......Spring of 1975.
Re: Big amps
#13 Post by Seth »
Bruce Weldy wrote: Fri Oct 22, 2021 6:28 pm
Yup. I was still in cloth diapers and probably still nursing in the spring of '75.
