Things that go boom
himhimself
Things that go boom
#1 Post by himhimself »
Finally making a start on T30 #3 and #4. Other than a few speakon jacks I think I have pretty much everything to make the matching pair. Not much free time, so will be slow. But better late than never.
2xT30 (20", 3012LF)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
Re: Things that go boom
#2 Post by Seth »
How wide are you going? Which drivers?
himhimself
#3 Post by himhimself »
3012LFs at 20" wide, just like #1&2.
2xT30 (20", 3012LF)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
#4 Post by Tom Smit »
Cool. Enjoy your builds!
Should this go in the "Builds" section?
himhimself
#5 Post by himhimself »
You're right, Tom, probably should. Is there a way to move a thread?
2xT30 (20", 3012LF)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
#6 Post by Tom Smit »
Bill has the authority, and maybe Chris.
#7 Post by Seth »
...Things that go thump in the night.
himhimself
#8 Post by himhimself »
Need to pick up some fresh plywood blades before I cut the access holes in the side. Got me thinking (dangerous, I know):
I was considering making the access flanges one-piece this time. Any reason not to do that and glue them to the backside right at the start? That would give a nice edge for installing the first panels. As I recall, it was a little bit of a pain to get those positioned and screwed in from the underside. With the flange already there, they could be butted up against it and pinned both to the flange and each other, then just clamped down through the access hole while they cure.
2xT30 (20", 3012LF)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
himhimself
#9 Post by himhimself »
Also, Bill, can you can bump this over to the build section? I'll continue to update as these come together. Thanks
2xT30 (20", 3012LF)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
#10 Post by Bruce Weldy »
himhimself wrote: Wed Mar 17, 2021 10:45 am
No reason at all not to do that. I did one-piece flanges on my last T39 build - great alignment tool for other panels and easier than trying to add 'em later.
Chris_Admin
#11 Post by Chris_Admin »
Tom Smit wrote: Mon Mar 15, 2021 8:30 am Bill has the authority, and maybe Chris.
Whooooshhh!
himhimself
#12 Post by himhimself »
Thanks Chris - you have the power 8)
And thanks for the vote of confidence on putting on the flanges first off, Bruce. Definitely going to do that.
2xT30 (20", 3012LF)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
#13 Post by AntonZ »
Chris_Admin wrote: Wed Mar 17, 2021 11:25 am
Whooooshhh!
Bill this site's Yoda is.
Chris though is at the controls of the warp engine 8)
Rich4349
#14 Post by Rich4349 »
himhimself wrote: Wed Mar 17, 2021 10:45 am Need to pick up some fresh plywood blades before I cut the access holes in the side...
Freud makes a rather good blade, and not TOO expensive.
Freud Diablo are excellent blades at a good price. They're much better than plain steel plywood blades. I use 100 tooth on my table saw, 60 tooth on my circular saw.
