Tuba HT 12 inch woofer, 15 inch wide
JensToft91
#1 Post by JensToft91 »
Hi all. First post.
I've been looking for the response of the smallest possible Tuba HT. 12 inch woofer, 15 inch width.
I'm thinking about replacing my corner loaded SVS PC-12nsd with the smallest Tuba HT, on it's side, used to extend the couch. (Is it called a chaise longue in english?)
I will be wall loaded, but i wonder if I'll loose response below 30 hz.
Best regards,
Jens
Re: Tuba HT 12 inch woofer, 15 inch wide
#2 Post by Seth »
JensToft91
#3 Post by JensToft91 »
Thank you! Guess i don't have to worry about low-end extension.
#4 Post by Seth »
JensToft91 wrote: Mon Mar 01, 2021 11:34 am Thank you! Guess i don't have to worry about low-end extension.
No, but your neighbors do. :)
