SLA Pro driver mounting
Short and Transmission Line Arrays for Pros
mattleis7
#1 Post by mattleis7 »
Hello! I just wanted a little clarification on how the drivers are mounted in an SLA Pro. The plans say to “screw the woofers in place” and no hardware is mentioned. Should I be using the cabinet screws mentioned earlier in the plans for this? Nothing else is needed?
Re: SLA Pro driver mounting
#2 Post by Bill Fitzmaurice »
Screws for the drivers have to be short enough to not go all the way through the baffle.
jimbo7
#3 Post by jimbo7 »
That's up to you how you wanna mount them. All of mine are held down with regular wood screws. Some use t-nuts or hurricane nuts, but you'll be fine with the same screws you're probably already using to build it.
Edit: Bill is right. You don't want the screw sticking out the wood. Also, full length threads.
mattleis7
#4 Post by mattleis7 »
Thank you both!
