Jack 12 Lite: Best Highs Choice
nola50
#1 Post by nola50 » Tue Mar 10, 2020 8:47 am
I finally (!) will be finishing my pair of Jack 12 Lites this spring and want to use them for bass and PA. I have completed one and used it on small gigs.
Which choice should I pick for highs that will give wide dispersion and best quality of sound? Is there an option that is not in the plans that has been determined to be exceptional?
And yes, it's all subjective.
Thanxabunch!
Re: Jack 12 Lite: Best Highs Choice
#2 Post by Bruce Weldy » Tue Mar 10, 2020 11:01 am
Thanxabunch!
Widest dispersion is the melded array - no question about that. Personally, I like the 1.2 crossover option with a horn for vocal clarity, etc. on a PA box. For bass....meh...don't really care for a lot of high-end anyway....
6 - T39 4-25" 2-22" 3012LF
4 - OT12 2512 Melded/NSD2005
nola50
#3 Post by nola50 » Tue Mar 10, 2020 10:08 pm
I have an OTB15 and love it's wide range for my Kubicki.
Guess I'll head in the melded array direction, which was my initial thought but I wanted to see if anything had changed.
NukePooch
#4 Post by NukePooch » Sat Mar 14, 2020 12:03 pm
I've built 4 Jack 112L.. Originally, two were melded, two were flat. I found that I liked the ultra-wide dispersion of the melded array enough that I converted the two flats into melded.
Those who've gone the compression drive route tend to say the sound quality is better than the piezo arrays (I don't doubt that it might be), but with the types of gigs I do, where people are up-close and around the speakers, the melded array fits the purpose for me. I love having a 'no bad seat in the house' speaker as compared to a more directional one.
nola50
#5 Post by nola50 » Thu Mar 19, 2020 3:11 pm
That's a deal on melded and the 1.2 crossover.
Now to chase the slice and build- won't that be fun!
#6 Post by Bruce Weldy » Thu Mar 19, 2020 3:48 pm
You shouldn't use the 1.2 crossover with the melded array.....that requires the 2k crossover.
#7 Post by Bill Fitzmaurice » Thu Mar 19, 2020 4:01 pm
You can't use the 1.2 crossover with the melded array, it won't work. You can't use the 2.0 high pass for the compression driver option with the melded array either. You may only use the piezo high pass filter.
nola50
#8 Post by nola50 » Thu Mar 19, 2020 4:23 pm
Understood, sir. Thank you!
