I might use theses plates so that i'm not in a bad situation if i happen to need a 1/4 or speakon.
Simplexx 212 build w/ Pics
- Electric Wisdom
Grill cutted and polished, ready to paint black
https://www.walmart.ca/en/ip/mainstays- ... 0195966751
I know that it is available in my store in Sarnia, ON.
- Electric Wisdom
Thanks a lot my friend, really appreciatedTom Smit wrote: ↑Thu Apr 05, 2018 12:15 am https://www.walmart.ca/en/ip/mainstays- ... 0195966751
If you use the 1/4 and speakon plate, make sure the 1/4" jacks are sealed, or use some blanks or non cabled jacks.
Don't want to introduce any leaks...
- Electric Wisdom
Yes totalyGrant Bunter wrote: ↑Thu Apr 05, 2018 4:01 am If you use the 1/4 and speakon plate, make sure the 1/4" jacks are sealed, or use some blanks or non cabled jacks.
I just got the foam
- Electric Wisdom
So i got the parts and i'm wondering if the mh value is including all the spare wire that comes off the coil itself?
If yes what should i do to not have a really too big crossover woodplate? Can i just make it in circles like the coil even if its not in the tie wraps?
Yes all the inductors length is part of it's value. Wind some of that wire back into the coil, with just enough out to connect to the other parts of the crossover.
Also, stand the smaller inductor upright, and place it 90 degrees perpendicular to the larger coil if it has to be that close.
If you have HF components, better to place the components for that filter on another board entirely...
- Electric Wisdom
Ok cool, yes well do i put the wire back in the coil hole or i make it so that it's like if there was more turns?Grant Bunter wrote: ↑Thu Apr 05, 2018 5:03 pm Yes all the inductors length is part of it's value. Wind some of that wire back into the coil, with just enough out to connect to the other parts of the crossover.
Yes HF crossover will be on the other wood plate, as the 3d model suggest he separated the hf crossover from the lf crossover
- Electric Wisdom
here's the crossover parts on a wood plate for the HF crossover only, i know i know i will buy the kits if it sounds not as expected because i used poly instead of elect caps but all the same values as the build doc.
hope it's ok
hope it's ok
- Electric Wisdom
I'll use something like this to connect in and out of each crossover
https://www.digikey.ca/product-detail/e ... ND/2283961
The high pass specifies polys.Electric Wisdom wrote: ↑Thu Apr 05, 2018 7:56 pm here's the crossover parts on a wood plate for the HF crossover only, i know i know i will buy the kits if it sounds not as expected because i used poly instead of elect caps
- Electric Wisdom
Right, my bad, i wanted to mean that all caps i bought at the moment are polyBill Fitzmaurice wrote: ↑Thu Apr 05, 2018 9:17 pmThe high pass specifies polys.Electric Wisdom wrote: ↑Thu Apr 05, 2018 7:56 pm here's the crossover parts on a wood plate for the HF crossover only, i know i know i will buy the kits if it sounds not as expected because i used poly instead of elect caps![]()
- Electric Wisdom
Just got the fancy block terminals to make a somewhat cleaner crossover than i thought
So excited
So excited
- Electric Wisdom
Holy moly i just did a test with the crown preamp, drivers are not even screwed in yet and i can feel it will be incredible
You had a picture with the finished crossover, looked very clean, you could put it back, as a good example!
