Do any of you guys have the schematics for a Crest 7200 lying around desperately needed.
Or any of the others?
Would be much appreciated.
Crest AMPS 1
Re: Crest AMPS 1
There's a block diagram at the end of the manual.Mkulu wrote:Do any of you guys have the schematics for a Crest 7200 lying around desperately needed.
http://peaveycommercialaudio.com/download.cfm?id=16712
For a full schematic, you may have to contact Peavey directly.
Re: Crest AMPS 1
Thanks Bruce,Bruce Weldy wrote:There's a block diagram at the end of the manual.Mkulu wrote:Do any of you guys have the schematics for a Crest 7200 lying around desperately needed.
Only block diagram, some ass has been into this thing and dropped solder all over the place.
Need the schematic for the component details so can measure. No schematic online will try peavey.
Thanks
Re: Crest AMPS 1
So much for PEAVEY they did not even bother to reply. Up theirs, I fixed the thang.Mkulu wrote:Thanks Bruce,Bruce Weldy wrote:There's a block diagram at the end of the manual.Mkulu wrote:Do any of you guys have the schematics for a Crest 7200 lying around desperately needed.
Thanks
