T60 High-Pass
PrismAudio
T60 High-Pass
#1 Post by PrismAudio »
So ive recently added 2 more tubas to my rig and ive got to say the bass response is disgusting in the greatest of ways. I only do sound for electronic music events.
99% of the time i have it set at 27hz on a 48db slope. however at the most recent past event i set it a 20hz which was pretty fantastic when a track was played that had that great big low end. The drivers survived the show so all good there but i'm wondering if i'm causing damage to the drivers
My Current Rig
Speakers:
4 - Omni 12
8 - J-Array Omni 12
8 - 2x12 Tuba 60s
Processing & Power
Console - Allen & Heath SQ6
Processing - DBX Venu360
SUBS - 4 x QSC PL236
LF Omnis - 2 x QSC PL325
HF Omnis - 1 x QSC PL325
CoronaOperator
Re: T60 High-Pass
#2 Post by CoronaOperator »
IDK, but if you bring that rig to the Hat during Ash's Easter show we can combine our 2 rigs for some real awesomeness :chainsaw: !
Re: T60 High-Pass
#3 Post by Grant Bunter »
CoronaOperator wrote:IDK, but if you bring that rig to the Hat during Ash's Easter show we can combine our 2 rigs for some real awesomeness :chainsaw: !
:hyper: :shock: 8)
Re: T60 High-Pass
#4 Post by Bill Fitzmaurice »
To have the same level of driver protection with a 20Hz high pass compared to a 27Hz high pass you'd have to halve the voltage limit.
Re: T60 High-Pass
#5 Post by DJPhatman »
Bill Fitzmaurice wrote:To have the same level of driver protection with a 20Hz high pass compared to a 27Hz high pass you'd have to halve the voltage limit.
Just out of curiosity, would the OP be better off setting a 24dB/oct @ 25Hz? Where would you recommend he high pass at, and at what slope?
Re: T60 High-Pass
#6 Post by Bill Fitzmaurice »
The recommended high pass is 25 to 30Hz, the ideal is 28Hz, if you have the ability to be that precise. The higher the slope the better.
