Bondo will always show through, with a change in the finish like you're experiencing. Duratex also does not adhere well to bondo, AcryTech specifically says not to use it. If you prep and primer correctly you can cure the adhesion problem. But the finish change never seems to go away. They say use drywall spackle, which I think is a mistake. Not strong enough.
I'm also though seldom filling anything much bigger than a nail hole.
You must have pretty wide glue joints. I've never had an issue with PL.
PL bleed through finish
Re: PL bleed through finish
- Jason Stromberg
I prime everything, it allows me to see imperfections before final coat.LelandCrooks wrote:Bondo will always show through, with a change in the finish like you're experiencing. Duratex also does not adhere well to bondo, AcryTech specifically says not to use it. If you prep and primer correctly you can cure the adhesion problem. But the finish change never seems to go away. They say use drywall spackle, which I think is a mistake. Not strong enough.
Yes spackle is great for drywall, not so much for cabinets but still i see people use it.
Glue joints are glue joints, everything gets brads and clamps. Not too often i use screws unless it absolutely necessary.
CoronaOperator
They have been smelling too many fumes over the years.LelandCrooks wrote: bondo, AcryTech specifically says not to use it ... They say use drywall spackle
On their advise I used drywall compound to fill some seams on a big project (our stage) before applying dutatex and that was the biggest mistake ever. Every patch lifted the duratex and left a big mess and a waste of 4 gallons of duratex. I used high strength compound that you have to mix with water and it sets hard and primed all the spots, didn't matter, it caked off from the bass. Everywhere I used bondo it held. From now on bondo will be the only thing I will ever use.
For duratex I sand with 50 grit with a random orbital then 2 coats, no undercoat. The 50 grit leaves plenty of scratches in the bondo for adhesion.
